Intermittent "Power system service urgent" message and battery light
So I just purchased an 05 2.4i, and off and on the Power system service urgent message lights up on my dash. There's no dimming of my lights or slowing of the fan blower motor when it happens, and there's no change of how the car runs or drives. Where should I start troubleshooting this problem?
start by putting a voltage meter on the car. Battery should be 12.6V with engine off. See what the altnerator puts out at idle and under full electric load (lights on, blower motor on full, rear defog on etc). Next is to inspect all cables - battery posts, ground strap etc - look for corrosion, bubbles in insulation etc. Its likely when the warning light comes on the alternator is not producing any volts and you're running off the battery only. This can be due to a bad voltage regulator or an issue with the voltage sensing for the alternator.
The car was just bought last week. The battery doesn't look to be that old but looks may be deceiving. I'll try wire brushing the battery posts and terminals first and see if that helps at all and if not I'll have the battery tested. I'd rather exhaust all my other options before I look into a new alternator or something of the sort
Did you get a new alternator? When mine started with the error message I replaced the alternator with a reman unit from one of the chain auto parts stores. The first one lasted for a couple of years. The second one lasted about a week. The third replacement was from Amazon and was listed as new. It was not a new one but it looked 5X better than the chain store versions. This one has lasted over a year so far.
After I got the car back on the road I took the original Volvo unit to a local rebuilder. He ordered good quality internal parts and rebuilt it. I know have a spare for when the current unit fails. If you have time and a local source then I would recommend getting yours rebuilt. It's still cheaper than the reman units.
