K&N Typhoon Intake
Old Mar 17, 2008 | 11:17 AM
SLVRS40T5's Avatar
Default K&N Typhoon Intake
I have a 2005 Volvo S40 T5 FWD and I want to get the typhoon cold air intake for it. I was looking at the massive airbox assembly and noticed there are a bunch of wires and stuff on it is this the ECU? When I get the cold air, where will all the electrical stuff go? Also can you really tell a difference in acceleration with the cold air?
Thanks
Old Mar 17, 2008 | 02:52 PM
mcguij1's Avatar
Default RE: K&N Typhoon Intake
no its probably the maf sensor and wiring
Old Mar 17, 2008 | 02:53 PM
mcguij1's Avatar
cold air induction is very good cheap mod for performance, but won't be as noticeable as a more drastic mod
Old Mar 17, 2008 | 09:52 PM
SLVRS40T5's Avatar
Would it make it shift any faster... I notice in I think 3rd gear while gunning it, it takes a while to shift to fourth. So where would the wiring go with a typhoon intake?
Old Mar 17, 2008 | 09:58 PM
S70driver's Avatar
Throttle response should be heightened a little. But don't expect to see major gains.
Downpipe and an ECU upgrade are what are going to get you bigger numbers.
Old Mar 18, 2008 | 03:41 PM
SLVRS40T5's Avatar
Of course, the expensive stuff. Do the chip's effect warrenty?
Old Mar 18, 2008 | 07:02 PM
S70driver's Avatar
ORIGINAL: SLVRS40T5
I cannot varify if they will or if they wont.
From what I can tell each Volvo dealership is different.
So it could affect it and it may not affect it.
Go at your own risk. If anything ask your dealership.
Old Mar 19, 2008 | 11:04 AM
euro3b's Avatar
DONT waste your money on a KN Intake.. Your better off to just add a Dryflow cone filter on the end of your intake pipe and just remove the intake box, its the same setup, just cheaper...
Rich
Old Mar 20, 2008 | 03:00 AM
primodevil's Avatar
ive got the same car with the typhoon... its sweet. it sounds great, helps the turbo spool and you can hear the waste gate a lil bit... it helps the motor breathe a bit better and gives the already peppy car an extra zip... thats also discontinued ik belive.... so grab it if you can....
hoff0477
Volvo C30
Oct 2, 2014 10:50 AM
xxdaly7xx
Dec 10, 2013 01:14 AM
C30T5
Intake, Headers and Exhaust
Jun 17, 2008 12:14 AM
92Typhoon
Jul 17, 2007 06:34 PM
