key hard to remove from 2005 S40
Probably just binding. First thing to try, buy some , use the little red spray tube and give that lock a good long rinse.
The ignition switch on my 2000 V40 would barely turn, after the silicone spray it's slick and smooth.
I just searched online for the best price. It was over $125 a while back. The price has gone up since then I'm sure.
It is a pain, but no cutting is required. The dash doesn't need to be removed and I'm pretty sure VIDA doesn't say it does because warranty time only pays like .9 if I remember correctly. With the center stack and the cluster out, you can remove the screw that holds the dash pad to the dash mount and there's enough room to get back there with a ratcheting bit driver. But it's still a pain, especially if you've never done one.
