Looking for trunk lock and other parts.
Old May 10, 2011 | 11:49 PM
Overload2020's Avatar
Default Looking for trunk lock and other parts.
I have a 2002 Volvo s40 and looking for hood gas shocks, sunvisor's, trunk lock and the driver side trim between the door and windshield. if you have any of these parts please let me know. Thank You.
Old May 11, 2011 | 07:37 AM
Choguy03's Avatar
You can get the gas shocks for the hood at any auto parts store. I don't know if you are trying to save money, but they usually are not that expensive. Found some on rockauto.com for $16.
Old May 11, 2011 | 03:38 PM
I'll check that site out but everytime i look for parts online its so much money. i rather find a car that has been smashed or being parted out so i can pick what i need at a very cheap price. the trunk lock is something i need pretty fast.
Old May 12, 2011 | 08:00 AM
Choguy03's Avatar
Just an fyi, I was reading a different thread and someone mentioned that they had a faulty sensor that wasn't allowing them to open their trunk. Try searching the forums, I am pretty sure it was for a different model Volvo, but it may be a similar problem.
Found it, from the Volvo S60 thread.
Originally Posted by orygunguy
My 2002 S80 has a wire harness that runs from the fuse box on the driver's side of the trunk to the lock assembly at the rear of the trunk. The wire harness is prone to becoming chafed or rubbed through the insulator and to short out on the metal deck lid, especially if the harness tie wrap is missing or broken allowing the harness to move around.
When this happens it is common for the fuse to blow in the fuse box and eliminate the ability of the FOB to electronically open the trunk lid. It is a fairly easy fix to replace the harness and the fuse.
A short term fix may be to wrap the existing harness with a bit of electricians tape. BUT that is a short term repair while waiting to get the harness.
I’ve replaced two on my 2002 S80. The first because it failed the second because I didn’t use a wire tie wrap to keep the harness tight in place.
Choguy03's Avatar
So check the fuse and the harness, if that is your problem of course.
Old May 18, 2011 | 10:57 AM
nerddad's Avatar
i have a 2002 also...my problem was the plastic piece that is on the back of the lock button broke. i can still go in through the back seat and use the cable to release the lid....i just ordered the kit from the dealer, it contains 4 or 5 pieces and costs about $20
Old Jun 13, 2011 | 03:28 PM
FatDaddy's Avatar
nerddad. I am looking for the plastic pieces between the motor and the shaft that goes down to the lock. My dealer didn't sound like they made a kit? You wouldn't happen to have a part number would you? I have a 2000 s40.
Thanks.
Old Jun 14, 2011 | 07:57 AM
nerddad's Avatar
the dealer faxed me a page from the parts program which was a drawing of all the lock/latch parts. the part i needed was among several parts which were circled on the drawing. (i have since thrown the fax away.) the circled items were ordered with one part number, this is what i was referring to as a "kit". however, those parts were on the back of the lock-- NOT at the motor.
if you can get the dealer to fax you the parts drawing it will help you a lot.
Ryan911t
Apr 13, 2014 10:19 PM
volvosaabtech1983
Jan 14, 2013 04:29 PM
x-angel
Jan 12, 2013 08:34 PM
Mie518
Apr 30, 2011 02:49 PM
Vincef
Mar 18, 2009 08:42 PM
