Name of these parts
Old Mar 18, 2019 | 10:52 AM
Newport_j's Avatar
Default Name of these parts
I need to know the name of the plastic part that is placed next the the headlights in a 2002 Volvo s40. I know what the headlights are called (obviously), but what are the apparatus right next ot them. There are two and they usually operate when I switch on the turn signals.
Any help appreciated. Tnhankls in advance.
Respectfully,
Newport_j
Old Mar 18, 2019 | 12:45 PM
you mean the park & signal lamp? google "volvo s40 30621837" (other side is # ..838)
Old Mar 18, 2019 | 06:26 PM
Newport_j's Avatar
Okay, thank, I will check it out.
Respectfully,
Newport_j
Old Apr 8, 2019 | 11:12 AM
Newport_j's Avatar
Oaky, I bought. It should be here by the end of the week. My next question is how to remove the central electronic module on a 2002 Volvo s40. Any diagram would help. Diagrams re much more
helpful than just written words.
Thanks in advance.
Respectfully,
Newport_j
Old Apr 8, 2019 | 11:35 AM
If the 2002 is the same as my 2000 S40, there's not much to show via a diagram. The CEM is located under the driver's side dash just above the hood release. its the box with 3 cables going into one side and there are two mounting screws. To remove the cables you need to push in the center tab and wiggle/pry to pull the connectors off.
As I recall, I had to remove the smaller cables first, then was able to spin slightly to get room to work off the larger connector.
whattodo
Apr 28, 2014 05:06 AM
dcjcdc
Mar 22, 2014 10:06 AM
pberejnoy
Jan 11, 2011 05:26 AM
volvoeric
Oct 6, 2010 01:42 AM
roytoronto
Feb 28, 2009 06:22 PM
