Need Help with Battery issues.
Hello All, So this is the 2nd time this has happened to me in 2days. I was driving to drop my daughter off to her Grandmothers I arrive shut the car off and drop her off within those 5-10mins the Battery was completely drained dead. I jumped it drove it home, The car did not do it for the rest of the day. Now i went to Little Ceaser's ran inside to get a pizza, less than 5mins go outside to start the car completely drained again. Vehicle is a 2000 S40. Any help is appreciated this is my only means of transportation and i have to put my 6month old in it and i really don't want this to keep happening with winter getting ready to roll in. Thank you.
First check your battery voltage with a digital multimeter set to DC volts. Engine off should see about 12 volts and engine running should see about 14 volts. (Multimeters are cheap investments and last a good long time.)
Given your description I'm guessing a dirty/loose battery or starter cable connection. Does the red positive cable have a white or blue crusty material all over the battery post?
I've never seen a battery drain in 5 minutes. When the car acts up do you hear a clicking sound when you try to start it?
Jeffers
11-21-2012 06:50 PM
lghyams
09-14-2009 04:45 PM
