need help - which headlights to buy?
eh, I'm a girl and I have to figure this out on my own.
I have a 2004 Volvo S40 T5. One of my low beams went out and I'd like to replace both headlights with the new bright stuff, the blue/white type of lights that light up the road but don't blind people.
I'm shopping on Amazon and I found:
Would these be the way to go, or are there others (I can buy on Amazon)
Thank you for your help
OK first question - does your car have Xenons or standard H7 bulbs? Xenons have a special ballast so you can't use true high output Xenon bulbs without the whole set up. Assuming you have standard H7 bulbs, the OEM is a 55W bulb, so if you drop in a 100W bulb, it risks pulling 80% more current - which can fry the wiring. Some brands like PIAA are 55W but state they have the equivalent lighting power of a 100W bulb. Not sure if that's really true but at least if its rated at 55W you don't risk an electrical issue. My personal opinion is the white/blue color doesn't really improve vision and I'd be wary of these "better" bulbs. Not the same as a true HID upgrade...
How about these? they are the same wattage:
Bulb, H7 Halogen, 55 watt. Flosser Ultra Lamp high performance bulb.
GermanAutoParts.com
GermanAutoParts.com
I've found the Flossers to have a long life which is important if you have day running lights. The Flossers last a year and you can't beat 6 bucks each delivered. I also have two vehicles that use the same H7 bulb.
If you just want to buy one or two, get the or the .
GermanAutoParts.com
GermanAutoParts.com
Having been down this road I decided to stop paying 20 bucks for bulbs that last 6 months and buy the cheapest standard bulbs.
Oh and you probably know this already but when you install these bulbs do not touch the glass envelope with bare hands, not even the slightest touch. If you do, oil is transferred from your skin which causes the glass envelope and the bulb itself to fail very quickly.
Behold the true nature of woman, lol. You're supposed to keep that secret. Team woman will be annoyed you let the cat out of the bag.
I'm not sure about the Gen2 S40s, but for my 2000 S40, I found I had to remove the battery to get access to the drivers side bulb. If your 04 is like us older folks (talking about my car, but I'm also on the AARP mailing list now.... ouch!) - open the hood and you will find a round 3" rubber cover on the back of the headlight. pop that off and you should see a spring clip holding the bulb in place. I find it easier to pull off the connector to bulb so you can slide off the connector then press the ends of the clip together then rocker away from the bulb. The bulb fits only one way with a small slot/tongue so when you insert correctly, it should center itself in the reflector. rocker the clip back on making sure the spring fits into its slots (this is where having small hands really helps...), then slide on the connector. look at the bulb from the outside to make sure its centered or the lamp will project in some odd way. Hopefully your 04+ is same as my 2000 here... as noted, try not to touch the bulb as any oil may shorten the bulb's life.
#18
Gen2 is FAR easier than the first gen models. Open the hood, pull up on metal bar holding light housing, gently push housing out the front. Now you have complete access to the housing without trying to fit your hand down behind the battery. I have a 2001 and 2005 and the difference is night/day.
Edit: trade secret. Go to Autozone or Advance and buy your bulb. Go at a not-too-busy time and ask very kindly if the counter guy can install it for you. My daughter has it down cold. She assumes the "poor little ole me, I'm just a girl" attitude and they are falling over trying to help.
Swer
01-09-2015 09:50 AM
ko_kidd
08-25-2006 08:53 PM
