Oxygen Sensor??
Old Jul 16, 2009 | 08:54 PM
benbtj's Avatar
Default Oxygen Sensor??
Details
2004.5 S40 T5
Check engine light on.
Diagnostic reader gives two codes:
P0031 - HO2S Heater Circuit Low Voltage Bank 1 Sensor 1
P0037 - HO2S Heater Circuit Low Voltage Bank 1 Sensor 2
From what I could gather searching threads this is the oxygen sensor? Some threads pointed out two sensors, is this the case in my vehicle. Either way, could someone point me in the direction of where they are and how hard it is to replace them. Instructions or a site redirect to instructions would also be greatly appreciated. If this is not the oxygen sensor, help in what it is would be appreciated as well.
Thank you in advance for any and all help.
Old Jul 23, 2009 | 07:13 PM
TIPSP's Avatar
Got Boost?
there is one sensor in the downpipe (before the cat) and a second sensor after the cat or in the middle of it.
wait for Tech, or someone to comment.....
Old Aug 17, 2009 | 08:50 PM
benbtj's Avatar
Default Help!!!
Okay, I replaced both O2 sensors. Cleared the codes and then re-read and came back as pass. About 1 hour later the check engine light came back on. Took it back and the OBD gave me the same two codes. What's next?
Old Aug 17, 2009 | 08:57 PM
Make sure there is no intake or exhaust leaks.
Old Jun 24, 2011 | 12:49 PM
Euro-lover89's Avatar
also check your fuses because your 02 sensors may not be receiving proper voltage due to a bad fuse...
soduku007
Oct 7, 2019 04:01 PM
habbyguy
Nov 10, 2014 07:01 PM
tomservo
Nov 27, 2005 11:50 AM
netflash
Jan 31, 2005 07:56 PM
