P0455
Old May 5, 2008 | 12:16 AM
chimmychong's Avatar
Default P0455
EVAP Gross leak
The ODB says large leak so i don't think its my gas cap also CEL doesnt come on after getting gas so I think the gas cap is ok...... any suggestions or somthing. thanks alot
My inspection was due a week ago
Old Aug 21, 2008 | 04:08 PM
jtz54's Avatar
Default RE: P0455
Having same issues with P0450, P0454 & P0455 intermittently.
Keep reseting with scan gauge but come back randomly. I suspect a cracked vacuum line
that goes away when warms up but haven't found it yet.
Old Aug 21, 2008 | 09:22 PM
Default RE: P0455
If the gas cap seal is good then the system needs to be inspected.
Old Aug 26, 2008 | 08:16 AM
Default RE: P0455
k i know this is a old post but i inspected all my lines and whatnot...
I replaced my purge valve and the CEL automatically went away
Old Aug 26, 2008 | 06:52 PM
Default RE: P0455
Glad you found it.
Old Sep 5, 2008 | 07:03 PM
jtz54's Avatar
Default RE: P0455
Where is the purge valve located?
Old Sep 5, 2008 | 10:20 PM
Default RE: P0455
On the cooling fan under the hood drivers side(USA car)
Old Jun 19, 2009 | 08:46 PM
hordezla's Avatar
Angry
After finding same code you guys had po455 and reading this topic i decided to change purge valve too. It didnt help, code is still there. Today i took the tank down to inspect charchoal canister and hoses, everything seems to be fine. What else to inspect, i cant pass inspection with cel constantly coming back for this one code.
Old Jun 19, 2009 | 09:00 PM
You need to somehow add pressure to the system and check for leaks.
Old Jun 19, 2009 | 09:51 PM
hordezla's Avatar
you mean like a smoke test? i thought of that too, i will do it if nothing else helps. i didnt think that gas cap could actualy trigger GROSS vacuum leak, now i am reading here that is possible too?!
Old Jun 19, 2009 | 10:00 PM
Yes that is very possible.
Yes like a smoke test. I made a special tool to add pressure to the system. Then spray with soapy water and look for bubbles.
Old Jun 19, 2009 | 10:06 PM
hordezla's Avatar
ok, gas cap is cheap, i will try that next. What kind of tool, if its something easy to make-please share so i dont have to pay for smoke test.
Old Jun 19, 2009 | 10:14 PM
This easy enough?
https://volvoforums.com/forum/volvo-s70-33/home-made-special-tool-18125/
I also use a vacuum/pressure guage with that.
Old Jun 19, 2009 | 10:32 PM
hordezla's Avatar
pretty neat
Old Jun 20, 2009 | 07:57 AM
Thanks!!
hordezla
Jan 15, 2024 01:32 PM
akb1274
Dec 7, 2020 05:32 PM
drbolt
Oct 5, 2007 08:58 PM
jbwinchester
Mar 31, 2007 12:47 AM
TBoone
Aug 8, 2006 12:52 AM
