Passenger side outer tie rod replacement
On Dec. 24, I took my 2002 Volvo s40 to a tire center to get a wheel alignment. They declined saying I need to replace the
passenger side outer tie rod before any wheel alignment is done. Okay I have found some ads for them on the internet. My first question is whether there is a difference between the passenger side outer tie rod and the drivers side outer tie rod. The following link for the most relevant ad is: Amazon.com: 2002 Volvo s40 passenger side outer tie rod which shows one made by Delco that is for sale around $ 58.17. They do not seem to make a distinction between the passenger side or the drivers side. Is there a distinction? Also, lower down on the page at the same link there is one made by Moog for $ 39.45. Again no distinction between passenger side and driver's side. So are these good outer tie rods. They come from reputable companies. Thanks in advance. Respectfully, Newport_j |
Both good brands yes.
I just replaced the ones on the 2002 S40, and they were different part numbers. So not sure on that deal. The tie rods were also stamped L and R. Question though......If one is worn, do you think the other will still be really good? No is the correct answer to that. ALWAYS replace them in pairs Easiest way is to hold the tie rod, and count how many turns the tie rod end is to remove, and thread the new ones on the same number of turns. Far from scientific or deadly accurate, but will get you close enough to get to the alignment shop. Martin |
Originally Posted by Leftlanetruckin
(Post 424037)
I just replaced the ones on the 2002 S40, and they were different part numbers. So not sure on that deal. The tie rods were also stamped L and R. Question though......If one is worn, do you think the other will still be really good? No is the correct answer to that. ALWAYS replace them in pairs Easiest way is to hold the tie rod, and count how many turns the tie rod end is to remove, and thread the new ones on the same number of turns. Far from scientific or deadly accurate, but will get you close enough to get to the alignment shop. Martin OP, this is an easy job. I recently replaced the passenger side rack boot on my steering rack, had to remove and replace the tie rod. Nothing to it. |
Originally Posted by migbro
(Post 424060)
I use the turn counting method plus orange spray paint. Then I do my own alignment.
OP, this is an easy job. I recently replaced the passenger side rack boot on my steering rack, had to remove and replace the tie rod. Nothing to it. How much can be done to the rack without having to drop the sub-frame? From the picture below, it seems like I have a power steering fluid leak. The boot that you changed is covered with fluid but does not appear to be torn. http://i63.tinypic.com/2cztvmc.jpg Never have I had any steering issues and am hoping I do not have to go the route of rack and pinon. TIA |
Why do you think you have a power steering fluid leak? It's impossible to tell from that pic what that fluid is or where it's coming from. The boot in your pic is on the drive axle not the rack btw.
I doubt that's a power steering fluid leak as there's a relatively small amount of fluid in the power steering circuit. If it were leaking that much you'd be topping off the power steering reservoir constantly. If it is in fact a power steering fluid leak, the first thing to try is a fluid exchange, an Auto-Rx treatment and a Magnefine in-line filter. |
