Is is possible to stop the seat-belt ticking sound?
I do wear my belt but if I'm looking for change for a drive-through or toll, or just stopped and want the engine running I don't like the ticking noise. Is it possible to turn it off somewhere? I tried disconnecting the plug to the seat-belt but it put on the airbag light which is probably not good.
It might be related to the seatbelt pretensioner mechanism, hence the SRS light coming on. The 'ticky-tock' box does not appear on any of the schematics I've seen but then again neither does the flashing light above the rear wiew mirror.
Hadn't thought of that. So as well as setting of the air bag I'm risking setting off some sort of firework in the seat belt mounting! Think I might stop messing around with it.
I just thought of another way you might be able to do it.See if you can find one of those seat belt extenders. Plug it into the latch and when you need to remove it just undo the belt itself leaving the extender in the latch assy.
Hi, not sure if it’s much help at the moment but the ticking comes from the fuse box in the drivers footwell, I recently bought a v40 and the ticking is very annoying so I’m trying to stop mine too, if I find the cause I will update this later
zpmada
Aug 22, 2012 09:19 PM
