Re-Calibrate Internal Temperature Controller
Old Nov 4, 2010 | 02:27 PM
jmartin's Avatar
Unhappy Re-Calibrate Internal Temperature Controller
2001 - S40 having problems with the heat as it gets colder, the engine warms up, heat flows from the heater but after 15 minutes of travel the heater stops blowing hot air and blows cold air, the heat does come back occasionally, changing the temperature setting does not help. Is there a way to re-calibrate all the temperature sensors that relate to the heater?
Old Nov 4, 2010 | 09:51 PM
Hudini's Avatar
Is this with the fan speed dial in auto? If so make sure it's all the way left. On mine if I bump the fan speed out of auto it will sometimes start and stop blowing randomly. I turn it all the way left then give it just a little extra "umphh". Not much, just a little more than simply turn it left. You don't want to break it off.
Old Nov 8, 2010 | 08:32 AM
jmartin's Avatar
No, this is not about the fan speed but temperature, you get hot air for a short time then it lets in outside air at 0 - 5 deg cel as that is the temp outside. Which holding your hand over an air vent will feel like freezing air.
northrup
Aug 9, 2009 03:01 AM
wolfman75
Jun 24, 2008 07:56 PM
v70dave
Apr 9, 2008 01:48 PM
sunnymaniaus
Feb 28, 2006 09:29 PM
brickhead
Sep 24, 2004 12:29 AM
