Really bizarre scary problem!
Old Mar 20, 2009 | 06:59 PM
  #41
Pull the top cover up and check the belt yourself. If it is cracking replace it.
Old Mar 26, 2009 | 07:28 PM
  #42
Lyonsroar's Avatar
OK, I've got an email in to an independant shop and they said they would do the thermostat, ECT and crankshaft position sensor. What would be a reasonable price for all of those?
Also the dealer said something about new software to go with the thermostat and ECT sensor? Anyone know about that?
Old Mar 26, 2009 | 08:02 PM
  #43
I would say labor wise about 2 hours or so for the ECT, sensor and thermostat.
Software BS not for that car!!!!
Old Mar 26, 2009 | 08:16 PM
  #44
Lyonsroar's Avatar
LOL!
So what is the software for then?
Old Mar 26, 2009 | 08:32 PM
  #45
They are feeding you BS!!!!
Old Mar 27, 2009 | 08:22 AM
  #46
Lyonsroar's Avatar
I'll rephrase: What do they think the software is for?
LOL!
The labor charge to replace all the parts you requested would be $337.50
The prices for labor are as follows:
- Thermostat 0.8hr $60.00
- Coolant Temp Sensor 1.3hr $97.50
- Crank Position Sensor 1.1hr $82.50
- Spark Plugs 0.5hr $37.50
- Ignition Cable 0.8hr $60.00
reasonable?
Old Mar 27, 2009 | 07:14 PM
  #47
Not to bad but the coolant temp sensor only takes about 3 more minutes to change when you are doing the thermostat so fight on that one. It should maybe be .05 at the most if you are doing the thermostat.
Sorry the software is a bunch of BS I would not even know where to begin to say they think it is for. LOL
Old Mar 28, 2009 | 08:13 AM
  #48
Lyonsroar's Avatar
The ignition wires are a little $$$ too I think.
Old Mar 28, 2009 | 09:05 AM
  #49
There should be no labor for the wires if they are doing the plugs.
Old Mar 28, 2009 | 05:25 PM
  #50
Lyonsroar's Avatar
I'll talk to them and see what they can do.
How in the world do I bring that up! LOL!!
ME: "I'm sorry, you shouldn't be charging for plug wires when you are replacing the plugs."
THEM: "hahahaha then you can find another garage!"
Old Mar 28, 2009 | 06:01 PM
  #51
Well they need to remove the coils and wires to change the plugs.
So you should not be charged since they are already removing them.
Old Mar 28, 2009 | 06:19 PM
  #52
Lyonsroar's Avatar
Good rationalization!
Old Mar 28, 2009 | 06:25 PM
  #53
LOL just speaking the truth.
Old Mar 28, 2009 | 06:47 PM
  #54
Lyonsroar's Avatar
Well my low idles back a little. When warmed up it sits at ~650 RPM's. Sometimes it dips down into the 625 zone.
Old Mar 28, 2009 | 09:11 PM
  #55
See if the tune up helps.
Old Mar 29, 2009 | 08:50 AM
  #56
Lyonsroar's Avatar
When the dealer cleared the codes it went away so maybe it has something to do with the crankshaft position sensor or the ECT.
I just don't know a whole lot about these cars...yet!
Old Mar 29, 2009 | 09:04 AM
  #57
That could be as well.
Old Mar 29, 2009 | 09:47 AM
  #58
Lyonsroar's Avatar
I'm gonna give them a call tomorrow and set up an appointment.
Once again thanks for all the help!
Old Mar 29, 2009 | 09:57 AM
  #59
No problem anytime.
Old Mar 30, 2009 | 03:54 PM
  #60
Lyonsroar's Avatar
Next thursday I'll be taking it out to European Motors in the morning.
It cranked hard again today after sitting in the sun all day. I'm f****** tired of this!
What are the symptoms of a failing crankshaft sensor BTW?
