replacing sparkplugs
Has anyone changed sparkplugs on a 2006 S40 2.4 my main question is do I have to replace the intake manafold gasket after removing it to get to the plugs?
Does anyone have instructions possible pictures on how to replace the sparkplugs?
Thanks, Costy
[align=left] [/align]
Thanks, Costy
If you're in central PA I'll do it for you. But no, you only have to remove the cover as far as I can see. You will have to remove the coil packs, but no gaskets. Chances are if there is a seal there it is just to keep dust out. Wipe it clean and you're good.
B
B
Ok ,so there is just a cover? I though that it was the intake manafold....This is the first car I have gotten that the I do not see the sparkplugs when I open the hood.
99civic, I am from CA and did lots of work on cars before but I learned to Question first and then try to do the work.. Thanks for you offer.
Costy
Costy
I can't answer for the newer models but on the older ones it's a coil-on-plug setup. 2 coils and 2 wires to the other cylinders. They are completely hidden by a beauty cover on the engine. Remove 6 torx bolts and then you see them. I have never run across a car that required the intake manifold to be removed but who knows what manufacturers could come out with in the future. Good luck!
How To: T5 Spark Plug Change
I know this write-up if fo the T5 engine,but this should give you a good guideline...
Rich
Rich
ORIGINAL: Hudini
ORIGINAL: mcguij1
well there's your problem, hondas are extremely easy to find everything, you have to use your torx and take the valve cover off, then you cant miss them, right on top of the engine.
B
