Roof Brake dim LED light
Old Aug 9, 2021 | 02:28 PM
FJDR-CL's Avatar
Default Roof Brake dim LED light
Hello:
My S40 2.0 COMFORT 2012 has a third brake led light. When light the led are dimmed. At night are seen a bit low as the common rear lights, In the day are too poor.
One- I do not know if it is a ground contact problem, where, or a defective fuse.
Two- Maybe I must replace it, but how is it?
Regards
Old Aug 9, 2021 | 03:42 PM
have you done any probing with a volt-ohm meter? I'd start by unplugging and inspecting connectors/cleaning up or scuffing up the contacts. From that point you can also probe to measure voltage and resistance to ground. You should also check a wiring diagram to see if the CEM is in the circuit path for the brake lights and you may want to check the pedal's switch as well.
Old Aug 9, 2021 | 03:45 PM
FJDR-CL's Avatar
I think it is the LED Light only, becase all other works fine
alfaromeo
Jul 15, 2015 03:10 PM
jeffro3r
May 23, 2012 06:09 PM
hammer1234
Sep 6, 2011 06:48 AM
cristiadrian
Nov 23, 2009 12:25 PM
Vlxx
Mar 30, 2007 11:44 PM
