Rough start and codes 2004 volvo s40 1.9t
Old Aug 3, 2021 | 09:41 AM
jw20874's Avatar
Default Rough start and codes 2004 volvo s40 1.9t
I have a 1.9t 2004 s40. Failed state emissions testing with codes p0015 and p0450. I've changed the oil multiples times and as I've heard sludge buildup is common in these cars with vvt, I'm the second owner so not sure how well car was maintained. Also changed vvt solenoid with no luck. I've heard the p0450 has to do with the fuel pressure sensor which in these cars is the leak detection pump is there any way to test the ldp for proper function? I changed a few evap lines which cleared my previous code p0456 afterwords the p0450 sprang up any connection? Also a hard start in the morning, usually starts the second time when I cycle key a few times to build pressure. Thanks
Old May 9, 2022 | 05:18 PM
jdrisc55's Avatar
your hard to start issue when you first start it in the morning does it start ok but then die off just idling but once you keep it running does it start ok for the rest of the day until the next morning and you have the same issue thanks
Old May 10, 2022 | 10:27 AM
Hard starting on a 1.9T can be caused by a leaking fuel pressure regulator (not sure if the 2004s are different from my 2000 which has a regulator not a sensor). Quick test is to find the pressure regulator on the driver's side end of the fuel rail, crank the car to build fuel pressure, then pull of the S shaped vacuum line on the bottom of the regulator. If you see fuel drip out, it has a torn diaphram which lets the rail loose pressure over time (thus more cranking on a cold engine).
Kirstenraye
Sep 16, 2019 08:34 AM
t-bone1924
Oct 30, 2012 07:57 PM
Franksauto
Oct 26, 2011 05:30 PM
Scancino
May 14, 2011 09:44 PM
hoffmandirt
Jan 24, 2010 06:25 PM
