Rubbing noise when engine runs
I noticed recently that my 2001 S40 makes this strange sound that sounds like a belt rubbing against something. It only does it if the car is driven a short distance or upon cold startup. If I drive it enough for the car to warm up completely, the noise is gone.
I checked the timing belt cover and it is on correctly.
Thanks!
Here's a video of the sound
Thanks!
Thanks!
S40 noise - YouTube
Thanks!
S40 noise - YouTube
does it change pitch when you turn the steering wheel (steering pump test) or cycle the AC on/off (AC clutch)? does it change pitch when you add an electrical load (high beams on/ rear defogger on, blower motor on) to test the alternator?
Did you listen around with a mechanics stethescope or try a rubber tube as a listener?
I am sorry, I forggot to mention that the timing belt and pump, also both aux belts, tensioner and alternator pulley had been replaced when I got the car 5000 km ago. What bothers me is that it sounds like that only for a few minutes at cold startup, so I think if it was some bearing it would sound like that all the time ( or am I wrong? ). I put in parts from INA, and the car is 2009 xc70 D5
In a situation like this, a mechanic's stethoscope is your best friend. Just catch it while the noise is still there, and check the serpentine (auxiliary) belt tensioner pulley, alternator, and anything else that's turning that you can get to (putting the probe on the non-moving part, of course). ;-) Hopefully it's NOT anything to do with the timing belt, but if you don't find it "above the timing belt cover", don't go too long without making sure it isn't something that's "under the cover".
Anyone solve the noise?
Hi did any one find out where the noise is coming from -- I have the exact same sound on my 2005 XC70. Thanks
