S40 cluster repair - LED
Old Aug 21, 2019 | 07:32 AM
RASO_S40_2.0D's Avatar
Default S40 cluster repair - LED
Hi guys.
Today i had some time and i dissassemby my cluster to change faulty LEDs.
I have some pics to show. I searched online but little info about this subject, so, here you have
https://1drv.ms/u/s!AlMVVubEH-i9vBeSbUFfgatneUVx
1 - First you have 2 screws on yellow;
2 - Press green arrow down and to your direction while pressing red arrows up a little bit, to loose the thing...then you have two fixations on the bottom, just pull it to you.
https://1drv.ms/u/s!AlMVVubEH-i9vB_KKen0J37aODAQ
3 - Remove those red arrows screws;
4 - Now, you have to be very carefull, cluster it's "locked" on the back. DO NOT PULL TO YOUR DIRECTION, you'll break it! Lift the cluster with some gentle force, and when you feel the cluster released, you can pull it to you and unplug the connections. One it's green in the top of the cluster, and the other one it's white on the bottom.
https://1drv.ms/u/s!AlMVVubEH-i9vBt_44E5jIofXr7G
https://1drv.ms/u/s!AlMVVubEH-i9vBnvYiIOxEElJG1w
pics of broken fixation attatched
Green plug connected here
https://1drv.ms/u/s!AlMVVubEH-i9vB4jgtwC90rscOiw
After that, cluster on bench and remove all the screws and open thing. this is what you will see...
https://1drv.ms/u/s!AlMVVubEH-i9vB2vn8Hve7NkJRkr
https://1drv.ms/u/s!AlMVVubEH-i9vBhpp5AFue5nA_fV
https://1drv.ms/u/s!AlMVVubEH-i9vBaElzo2oJthhf8Y
https://1drv.ms/u/s!AlMVVubEH-i9vBXAvXjlp-8J9lkF
https://1drv.ms/u/s!AlMVVubEH-i9vBy-F2iw0GiTGEyX
if someone need more info that isn't here, feel free to ask :thumbup:
sktrmoss
Jan 15, 2011 11:27 AM
xxbrittonxx
Oct 20, 2010 08:42 PM
Carlin
Aug 18, 2010 10:53 AM
Rob`s60
Aug 13, 2007 02:34 PM
cool_kyle_3000
Mar 5, 2006 11:40 PM
