S40 headlight
Old Jan 14, 2022 | 02:38 PM
c0uger67's Avatar
Default S40 headlight
2003 S40 my passenger side head light won't work. It is not bulb.
Old Jan 14, 2022 | 07:55 PM
If there is no power getting to the bulb - Commonly a bad CEM can be the problem. The relays inside fail. xemodex sells CEM's with upgraded relays. Or the control module is not "coded" to your VIN so a used one would be plug and play unlike most other 99+ Volvo CEMs
Old Jan 17, 2022 | 05:12 PM
check out car-part.com for yards near you that may have a gen 1 S40/V40 or check out eBay. The CEM is the gray box with 3 large connectors going to it under the passenger side dash right above the hood release. I got a used CEM for $65 to fix my headlights.
Old Jan 25, 2022 | 10:43 AM
GySgtE7USMC's Avatar
I had same problem with left side low beam replaced and still no light .
DUH it was the left side low beam fuse under the hood.....check them
S40 in Fla
Jun 7, 2013 11:50 AM
nigel_miguel
May 22, 2011 07:18 AM
Greenmudshark
Oct 23, 2009 03:08 PM
noarch
Oct 20, 2009 07:02 PM
ev0lved
May 14, 2008 04:42 PM
