S40 Interior Lights
Old Apr 7, 2019 | 08:06 AM
VLP's Avatar
VLP
Default S40 Interior Lights
Have a strange issue, interior lights go on. 2nd one goes on, than both is dim. I have checked the fuses #47 & #86. Both in order.
Anyone can help?
Old Apr 8, 2019 | 12:08 PM
what year S40? Sounds like a ground issue or a switch issue (ie dirty contacts)
Old Apr 8, 2019 | 06:32 PM
Hudini's Avatar
Did you check all the fuses?
Old Apr 9, 2019 | 01:45 PM
VLP's Avatar
VLP
To be honest, only #47 & #86
Will give it a bash and check all. Will let you know the outcome. Hoping to find the faulty 1
Thanks.
Old Aug 27, 2019 | 09:11 PM
pmondrian67's Avatar
Default Interior Overhead lights
Were you able to solve your problem? I have a 2005 S40 and the same problem just started. With one interior light on (either front or back), it is bright. But a second light on causes both of them to dim. I've checked my fuses as well.
Anyone can help?
Old Aug 29, 2019 | 11:04 AM
habbyguy's Avatar
Bad ground somewhere. Might be difficult to find though...
Old Aug 29, 2019 | 08:01 PM
Default It was a Fuse
I checked the fuses again. There was an additional one that was bad that I had missed. In the end, I had to replace two 5A fuses. Now it all works. Thanks!
Hudini
Mar 30, 2020 06:06 PM
volvo 1997
May 5, 2014 03:44 AM
Steve_F
Oct 2, 2013 09:40 PM
tonka12
Apr 21, 2010 12:22 PM
bentstorey
Oct 7, 2009 04:12 PM
