S40 rattle with VIDEO
So I have a 2007 s40 AWD type R. It slowly developed this rattle that almost sounds like something is rattling against the bottom of the car on the passengers side floor board. Everything seemed tight on the front end but the bushings on the back of the control arms looked worn out and sounded to be a common source of rattles. So I replaced both lower control arms. Exactly same thing. So then I thought it could be the wheel bearing, replaced if.... same thing. I also left the car in 1st with the engine off and tried to rock the car back and forth to see if the engine is moving. Which it doesn’t appear to be. I currently have it jacked up and only see one exhaust hanger pulled off (near the rear end. None the less here a video of the noise.
Still trying to find this rattle. All of the exhaust is tight, all of the mounts are tight, suspension is tight (when on a jack). It makes this noise when I barley turn right or give it gas. Starting the think it’s the subframe mount on that corner. If I’m the passenger I can defiantly fell it in the floor board. I found a TSB but It doesn’t look like it includes the s40. Anyone had to add the Orings to the rear mounts on the front subframe of their s40?
mark0006
05-06-2016 01:43 PM
