S40 starting only in N
Old Aug 12, 2007 | 12:43 AM
brobertsn's Avatar
Default S40 starting only in N
I havehad a2000 S40 for over 5 years with no problems,but only recently it is giving problems starting,after read a thread in this forum I saw the idea of starting in Neutral and it worked ! This has saved me some $$$ as I was going to have a mechanic check it out.Now can some please let me know what the problem is and is this the tip of a much bigger iceberg?
Old Aug 12, 2007 | 06:42 AM
Default RE: S40 starting only in N
If it will only start in neutral then most likely it is a bad PNP switch.
Should be a couple of hundred dollars to get it replaced.
michaelm
Jan 6, 2013 08:06 AM
nigel_miguel
Jul 31, 2012 12:06 PM
Qamar
Aug 8, 2005 02:32 PM
