Shift Knob
Old Jul 29, 2005 | 02:51 PM
ZIGZAG's Avatar
Default Shift ****
I was wondering if any one could explain to me how to replace the shift ****. I don't want to rip apart the console with knowing what to do.
Old Jul 29, 2005 | 03:29 PM
Default RE: Shift ****
Where the boot meets the **** you will need to turn it to release the clip inside the boot.Then slide the boot down.Then grab and yank the **** off.
Old Jul 29, 2005 | 05:04 PM
ZIGZAG's Avatar
Thanks tech I will try that this weekend, hope I dont break it.[&:]
Old Jul 29, 2005 | 09:33 PM
As long as you get the boot loose from the **** then you will be fine.
You are replacing the **** correct?
Old Aug 3, 2005 | 03:09 PM
ZIGZAG's Avatar
I am going to replace the ****, the stock one is very sticky and when i shift into park button does not disengage, can't get key out. have to force button manually. I hope to get new shift **** this weekend. By the by, took me over a week to figure out what was wrong, guy at dealership knew right away. sounds like a common problem.
Old Aug 3, 2005 | 09:56 PM
Yes somewhat.
elbert
Aug 20, 2006 07:55 PM
tupapison
Jul 1, 2006 10:15 AM
jfspring
Jan 29, 2006 12:00 AM
Superfly
Jan 18, 2006 01:15 AM
jcmartin
Sep 20, 2005 08:54 PM
