Shift knob moving?
Old Jun 29, 2006 | 07:01 PM
tupapison's Avatar
Default Shift **** moving?
Whenever i press the brakes on my car, and my hand is on the shift ****, i can feel it moving forward, is this normal or what?
Old Jun 29, 2006 | 07:24 PM
Clueless Scott's Avatar
Default RE: Shift **** moving?
Sounds like a bad VARILLA to me !
[sm=badbadbad.gif]
Old Jun 29, 2006 | 08:16 PM
tupapison's Avatar
>_>.....No the VARILLA is the thing making the clunking sound, i mean its not MOVING like from one shift to another, but i can feel it moving a little bit
Old Jun 29, 2006 | 08:25 PM
Well, as long as you don't feel it in neutral, I think you'll be OK.
[sm=yikesomg.gif]
Old Jun 29, 2006 | 08:44 PM
tupapison's Avatar
Its only when i brake >_> I NEED HELP
Old Jun 29, 2006 | 09:19 PM
The rear Rotors are warped!!!!
Old Jun 29, 2006 | 09:27 PM
tupapison's Avatar
The rear rotors? Volvo 940's have IRS or not? well at least mine?
And also, my steering wheel still shakes when im going 50MPH, why is that? the wheels are new, they were balanced, so i dont get it
Old Jun 29, 2006 | 11:27 PM
Not sure if you have IRS would have to look at it.
But you have rear rotors anyway. When they are warped the shifter will bounce when braking.
The steering wheel is either a tire out of balance or out of round.
Old Jun 29, 2006 | 11:47 PM
tupapison's Avatar
The tires are new and just balanced, what do you mean by out of round...
Also, how can i know if my car has IRS? i mean its asking me that to purchase them :S
Old Jun 30, 2006 | 12:23 AM
Just because new doesn't mean it is all good. Also if you hit a Pothole it could have knocked a weight off.
Out of round means there is a lump in the tire and it is bouncing when driving.
Look under the Back of the car. See if it is one solid metal piece where the tires go to.
IRS would have an Axle that can be seen on each side. It will look like a front wheel drive Axle.
Most likely you have a solid Axle.
The IRS is mostly in the 940 SE and the 960's
Old Jun 30, 2006 | 12:52 AM
tupapison's Avatar
But like i said, the tires cant have a lump because they are brand new, and as soon as they put the tires on, i felt the same thing :S
Old Jun 30, 2006 | 12:55 AM
If it was there before the new tires then maybe a bad bushing.
But remember new doesn't always mean it is good!!!
I have had Many Many brand new part that were bad.
Old Jun 30, 2006 | 01:54 AM
tupapison's Avatar
Yeah, ill just leave that alone, because when im going at 60MPH, the shaking stops so its ok =], and what would happen if i dont change the rear rotors? also, the left rotor was making an awful noise like 2 years ago, and we fixed that by doing something to the rotor
Is a 2002 Volvo S60 2.4T ok for 11k?
Old Jun 30, 2006 | 08:06 PM
tupapison's Avatar
we fixed the rear rotors like 2 years ago because one of them was making an awful noise, well we only got one fixed
Old Jul 1, 2006 | 10:15 AM
If you don't replace them it will just be annoying. NO danger at all.
carlosr23
Jan 17, 2013 04:52 PM
pfoy
Jul 29, 2007 02:43 PM
Superfly
Jan 18, 2006 01:15 AM
jcmartin
Sep 20, 2005 08:54 PM
ZIGZAG
Aug 3, 2005 09:56 PM
