Slow starting
Old Aug 30, 2007 | 09:49 AM
02VolvoS40's Avatar
Default Slow starting
Hey guys, my '02 Volvo S40 has been starting really slow for the last couple weeks. It takes about 4-5 seconds for it to finally role over and start. I have had my battery tested and it came out fine, so I figured it's my starter. However, I called my local shop that specializes in European cars and they said Volvo's have a known faulty wire from the starter to the battery. I'm just checking to see if anyone has heard of this. Thanks!
Old Sep 2, 2007 | 05:53 AM
JPN's Avatar
JPN
Default RE: Slow starting
Hi,
I just checked for possible recalls on '02 S40, and there was nothing related to the starting system (only some child-seat anchour-related recall was found).
As to the possible faulty wire, you'd have to wait until a gentleman by the name of Moderator Tech replies. Now, when you turn the key to "START", how does the starter respond? Does it turn slowly, or does it barely turn?
Please let us know the brand name of the battery, how old it is, and whether the connections are clean or corroded. I don't know what tests the shop did, but usually there are 3 tests to ensure correct battery condition:
1) Voltage test: 12.2-12.6V with engine off, above 13V and less than about 14.5V with engine running.
2) Specific Gravity test: Each cell should read 1.275 at full charge, 12.5 for average, etc...
3) Load test: Has to be done with certain equipment.
If the battery is absolutely fine, then the problem is either the starter, its connections or some additional drag/load placed on the engine when cold (though this one is not very likely).
Lastly, drive to a local AutoZone or other auto parts shop and have it tested with an OBD-II diagnostic scanner, and if there are any codes,ask them to show you the code & fault descriptions.
Will wait for your update.
JPN
Old Sep 2, 2007 | 12:48 PM
02VolvoS40's Avatar
Thanks for the response. I will try to answer your question best I can since I'm not great with the correct vocabwhen it comes tocars. First of all, let me say this... sometimes it actually starts right up, but that only happens about 20% of the time. When the problem occurs, I turn my key to start it up and everything actually sounds like it normally does. Well, with exception to the car completely turning on. Nothing sounds "slow" about itin my opinion. There's a good couple of seconds delay before the car finally starts up.
My battery is Volvo OEM, 2 years old with justa little corrosion. This was my wife's car and it died when she was out of town and that's whattheyput in it.
I will let you know if any codes show up.
Old Sep 2, 2007 | 02:11 PM
JPN's Avatar
JPN
Hello,
You can bealmost sure that the battery is ok. In general, a quality battery lasts between 4 to 5 years with proper care(with the exception of premium maintenance-free batteries, which seem to last longer).
With my limited knowledge on the S40, I can only assume that the starter itself is going south, or the relay for the starter is about to give in, or the electrical portion of the ignition switch is going bad. This can only be answered either by Moderator Tech or other S40 members who have had similar problem.
Wait a bit more to see if someone with better knowledge than I replies shortly. If no one replies soon enough, have a visit to a local AutoZone/parts shop and if their scanner does not show anything, then you may want to visit a garage that specialises in Swedish/European makes for further trouble shooting. You may also choose to visit a dealer, but if you take this route, try to sound as knowledgeable as possible, as some dealers have tendency to sell you unnecessary parts/services by "scare-tactics", telling you that so and so parts are failing and if you don't fix it now (which costs $1,000[8D])it will cause more damage, which is BS.
I'm sorry I couldn't help you better.
JPN
Old Sep 6, 2007 | 01:15 PM
02VolvoS40's Avatar
Ok, I finally had my codes checked today and it passed. It found no codes. I'm almost convinced that it's my starter and I think JPN confirmed the same feeling. However, due to the location of the starter on our S40's, they wouldn't test it for me. I guess I'm going to have to bite the bullet and take it in to my local shop that specializes in European vehicles. How much am I looking at and is it something I can do my self? Despite my bad "car" vocab, I'm actually pretty good and fixing things. I even replaced my driver's side window regulator. Would it even be worth doing myself?
Old Sep 18, 2007 | 10:12 PM
jojoswhip's Avatar
I had the same issue and it got worse. Check your fuel pressure regulator. I bet that is the problem! about $90 for the part and farely simple to replace
Old Sep 20, 2007 | 08:45 AM
02VolvoS40's Avatar
I think you're right! After doing some research, that sounds exactly likethe problem. Did you replace yours yourself and if so, do you care to share how you did it? The labor is well over $300 and I'd prefer to do it myself if possible. Thanks!!
Old Oct 1, 2007 | 08:45 AM
02VolvoS40's Avatar
Update: That was it! The fuel pressure regulator. Got the part for $80 and did it myself. Was very easy thanks to Tech's post in another thread:
https://volvoforums.com/m_47873/tm.htm
If I can do it, anyone can. Anyway, thanks to all those whohelped me, especially JoJo in this thread and Tech in the other thread. Made my weekend to know I wasn't out a lot of money. (they estimate labor on that $350 and my local dealer wanted $50 just to diagnose it). [sm=smiley20.gif]
Old Oct 6, 2007 | 07:25 PM
chrisl's Avatar
I have a 2005 S40 T5 and I had the same problem when I was running the premium gas (93 octane).
I switched to Cheap gas, the cheapest stuff that Amoco, BP, and mobile have to offer and my car starts fine.
These cars run greate on regular unleaded
Old Jun 8, 2013 | 03:04 PM
mg0698's Avatar
Hey guys I have a 2000 Volvo s40 it takes a while to start maybe 7 seconds when it has been sitting there, But if I just started it and came back 10 mins later it would start right up.
I changed the fuel filter, air filter spark plugs. Problem remains. I took it to the auto shop they tested the battery and said it was fine, But said th alternotor is on it's way out.
But I have been reading on here it may be the fuel regulator. So What do you guys think?
Once it starts it drives perfectly.
Old Jun 8, 2013 | 03:27 PM
Hudini's Avatar
3 posts on the same subject?
Old Jun 9, 2013 | 10:34 AM
mg0698's Avatar
Sorry, I was trying to spark an update by previous posters.
I think I will try to see if my volvo has a shrader valve that I can test the pressure. Then switch the FPR.
Are any of the symptoms mentioned signs of a bad alternator? This problem has been going on for a while. I would assume with a bad alternator one day it just wouldn't start but it starts every time just takes a long time cranking.
Old Jun 9, 2013 | 05:37 PM
Hudini's Avatar
The alternator should not have anything to do with long cranking as its only job is to charge the battery. When the alternator goes bad you should get the red battery symbol on your dash as the battery is not being charged. Then when the voltage from the battery gets low you may get all kinds of strange electrical gremlins. This car hates low voltage (probably all newer cars too). Also when attempting a start you get "click, click, click" as the starter bendix tries to engage the flexplate but the starter motor does not get enough amps to turn the engine.
You can check the voltage at the battery with a digital multimeter. These are cheap and available at any hardware store. You want about 12.2 volts engine off and 14.4 volts engine running.
Good luck with your car and definitely let us know how it goes. When my 2001 had the long cranking I first replaced the IAC motor for $200. Then I searched and found this forum which directed me to the FPR which fixed me right up. Back then the FPR was $80 from the dealer. It's way more expensive now though. Easy to DIY though. One vacuum hose, one fuel line, one bolt.
Old Jun 11, 2013 | 11:35 AM
mg0698's Avatar
Thanx a lot Hudini
I ordered the part today. I will update this thread when I switch out the part.
Old Jul 25, 2019 | 05:41 PM
2002volvov40's Avatar
Originally Posted by mg0698
Thanx a lot Hudini
And??
Old Jul 25, 2019 | 10:10 PM
and considering you are reading a six year old post, I'm sure Hudini won't mind me chiming in by saying his car is in good working order :-)
As to the general theme of the thread - if your car turns over slowly, its battery/cables/starter. If your car cranks for say 15 to 30 seconds or longer, you are in spark/fuel territory. The Gen 1 S40s FPRs have a diaphram that is prone to tear which allows the fuel pressure in the rail to drop after sitting and it takes the pump some time to build it back up. If you pull off the vacuum hose on the bottom (not visible in the pic) and fuel drips out, the part needs to be replaced. BTW, its also a crazy expensive part ($200+) for something that takes 15 minutes to replace...
Old Jun 15, 2023 | 11:13 PM
  #17
Aaron4001's Avatar
Default Volvo s40 2009
I’m having the same delayed start problem but I can’t find the fuel pressure regulator or find the location of it. If anyone can help me out before I go to a mechanic it would be helpful
Old Jun 16, 2023 | 07:01 AM
  #18
Dingus1's Avatar
I am pretty sure in the 09 they have a variable pressure fuel pump that operates in conjunction with a fuel pressure sensor on the end of the rail, no regulator. 2002 is a different story. You should have a schrader valve (like a tire valve) on your fuel rail where you can test pressure with a gauge.
Old Jun 16, 2023 | 09:21 AM
  #19
Aaron4001's Avatar
Default So should I replace that variable pressure fuel pump?
And if you can can you please send a link to the part. I can’t find anyone else replacing it it’s really confusing
Old Jun 16, 2023 | 12:14 PM
  #20
Dingus1's Avatar
I would use Tascaparts.com and search it up. There a few variations of the s40 so it could be one of many pumps depending on your trim. It is all detailed on the site about which pump is which.
https://www.tascaparts.com/v-2009-vo...ted-components
example for 2.4i
Metroatlanta
1998-2000 model year V70
Jan 25, 2018 08:04 AM
celjock
Jan 10, 2016 03:03 PM
von
Mar 1, 2010 02:58 AM
dpallen
May 18, 2009 03:40 PM
sasha1
Jan 3, 2008 09:38 AM
