Someone help me with phase.
This any help to you?
... as a rule of thumb the early phase 1 T4 had the 1855cc unit with the phase 2 having the 1948cc unit, both T4 engines producing 200bhp/147Kw.
Phase I
1998 - B4194T = 1855cc (high pressure turbo)
1999 to 2000 - B4194T2 = 1855cc (hpt)
1998 to 2000 - B4204T 1948cc (low pressure turbo)
Phase II
2001 to 2003 - B4204T5 = 1948cc (hpt)
2001 to 2003 - B4204T3 = 1948cc (lpt)
Check the white sticker on the side of the black timing belt cover for engine type.
Phase I
Phase II
That sticker should also have the engine number.
You could verify the actual engine spec's via a Volvo dealership if you quote that number.
It is all vaguely described and a bit confusing but also refer to the links below.
The T2 was produced in both an 1855cc and a 1948cc version available on Phase I's 1998-2000. The B4204T2 has the low pressure turbo whilst the 1855cc has a high pressure turbo.
The T3, as is in my V40 was fitted to Phase II models, 2001 thru to early 2004, also 1948cc.with a low pressure turbo. (B4204T3)
VOLVO V40 - 1996, 1997, 1998, 1999, 2000
Volvo S40 - Wikipedia, the free encyclopedia
Checking out by using your actual engine number is your best way of being sure.
