Something Wicked This Way Comes On The 06 2.4i
Well, it's been a little over a month since I did the timing belt and water pump job on this car. I drove it last friday and could've sworn I smelled coolant in the car. When I got out of it I couldn't see anything leaking. The wife calls me last night from the grocery store saying she thought it was going to catch fire. So I drove down there and I couldn't see anything obvious. So I told her to drive my service truck home and I drove the volvo. It did fine it seemed until I'd driven it about 6 or 8 miles. I was watching the temp gauge and it went a little over the halfway mark which it's never done that I know of. It came right back down to where it normally runs (about the halfway mark) and I smelled coolant in the car again.
I got it home and pulled under my patio and looked all over it. I didn't see anything leaking. But it was a little low on coolant. She said she could hear a boiling noise. I got out there a little while ago and let it run until it got up to operating temp according to the gauge. The one thing I noticed was that when I turned the heat on it wouldn't blow any hot air. She said it's been like that since we got it. You had to start driving it before it would start blowing any hot air she told me. So that doesn't sound right to me. I could see where it looked like some had been pushed out of the surge tank onto the timing cover and dried. So I started thinking maybe a sticking thermostat or possibly a faulty heater control valve. After I shut it off I seen something dripping from the bottom. I thought it was condensate from the A/C. But it's definitely coolant leaking. Before I got it jacked up I was thinking a defective water pump. But it's not leaking in that area. It's coming from a little farther back. I couldn't nail it down because of all the shields in the way. But it's coming from the right side floorboard area and dripping onto the rear subframe beam. I'm thinking that has to be the heater core. The only other thing I touched on the cooling system was the surge tank. I over filled the original one a tad when I got done with the timing belt job and noticed that it was pushing out of the top of the tank where it had some tiny spider cracks in the top. I replaced the surge tank and thought I was done with it for a while. Looks like I was wrong about that. I was just wondering if anyone has had a similar problem and what it actually turned out to be. The only conclusion I can come to so far is that the cooling system wasn't holding pressure due to the surge tank. Now that it should be with the new tank. Could that have started a leak with the heater coil or something else entirely? |
check the carpet in the foot wells for wetness - you could have a slow leak in the heater core or its hoses. That would give you a smell of antifreeze as well. Also inspect the hoses from the block through the firewall for the heater to see if those are leaking. If the S40 is like the 850s you should be able to remove the lower trim on the sides of the center console to get a look at the heater core. I need to do this repair on my daughter's 850 (just waiting for warmer weather!). Could be as simple as replacing the o rings where the hoses meet the heater core as well.
Originally Posted by mt6127
(Post 408545)
Yes, the coolant tubes do join to the heater core at an O-ring sealed union. I believe he joints are in the passenger foot well.
Well, the wife finally talked me into putting in the new heater coil. Whoever designed it the way that it is should be taken out and killed very slowly and painfully. I need a little advice because I'm stuck in one spot and have been trying for hours and haven't gotten anywhere. I have the new coil in place but I can't get the plastic couplings that hold the pipe extensions on the coil together to stay put. There's very little room to work and I can't really see what I'm doing. I'm basically trying to feel my way through it. The few times I was able to get one of them on properly it pops back off as soon as I try to put the other one on. There's got to be a trick to it that maybe someone here can tell me.
Have you seen this?
Heater Core O ring replacement Thanks heavens I have not had to learn about this first-hand.... yet. Let us know how it goes! |
Originally Posted by mf70
(Post 413279)
Have you seen this?
I feel your pain! The key for me was the proper size o-rings and a set of helping hands. Place the o-rings inside the female ends, not onto the male ends. Have your helper hold the female pipes from the firewall side while you gently push the halves together. You need just the right angle to avoid damaging the o-rings. I chamfered the male ends a tad and used grease. If you put the o-rings on the male ends the stupid plastic clamps will not fit.
Above you mention o-rings on the plastic twist locks. These probably do have some sort of o-ring inside but it should be integral to the twist lock and not something you add. The o-rings I mention go in between the metal pipes inside the car. These were the source of my leak. |
Originally Posted by Hudini
(Post 413430)
Above you mention o-rings on the plastic twist locks. These probably do have some sort of o-ring inside but it should be integral to the twist lock and not something you add. The o-rings I mention go in between the metal pipes inside the car. These were the source of my leak. So as I said, I had to put it all the way back together pretty much so I could start it. As soon as I did, the coolant started pouring from the top hose fitting where it locks on to the extension tube on the firewall. So in the process of trying to see what was going on with that. Pulling it off and back on to make sure it was right. Well the clamps popped loose again! AFTER I had already put everything back together inside the car. I cut the plastic twist lock connector off the top hose. I took the bottom one loose(it also came apart inside) and cut one of the old tubes and bypassed it for the time being. I decided I had enough and was going to tell her to bring it to someone else. But I got to thinking about it yesterday. I was just going to go ahead and do it and then post here about it. But I don't believe it would hurt to have a little input. I believe I can make it a helluva lot better than the way it came. I'm thinking about ordering some high quality silicone hose and some good heavy duty stainless steel hose clamps. Cut the ends off the tubes and the coil and push the hose on the tubes and the stubouts of the coil and tighten the clamps up real good. I'll bet a dollar to a doughnut that those hoses and clamps will outlive those o-rings by a long shot. What do ya'll think? |
I recall reading a similar post (perhaps on the 850 board?) where they replaced the hoses through the firewall with generic tubing then used stainless hose clamps to secure to the heater core with good results.
I broke one of the plastic twist locks too. The dealer had them in stock for a decent price so I was lucky. It's a totally over engineered system.
I think your idea will work if you enlarge the holes in the firewall for the new hoses. Space through the center console will be tight also. I would consider putting some kind of flair on any shortened pipe to prevent a hose slipping off. |
(Post 413499)
2 Attachment(s)
Well I wanted to update this one. I got this done a couple of weeks ago now. I've just been too busy to update it. It's got about 500 miles since I did the job and so far I've had no issues. In my haste I forgot to take pictures of the inside. But I took pictures of what I did on the outside. It looks about the same on the inside. It's just 2 short hoses and 4 clamps. It's real tight with the larger hose inside the box but I made it work. You have to make sure that the clamps on the inside are turned with the worm gear towards the driver side. Or else the ECM wont bolt back in its spot. Maybe I should send these pics to Volvo and tell them I'll take a low 6 figure salary versus a high 6 figure salary and I can make this stuff last the lifetime of the vehicle! If I would've had more time and the car up in the air. I would've discontinued the twist lock hoses completely instead of just the short extensions that go to the firewall and hook up. At least if it leaks now it should be contained to the outside which will be much easier to fix. Hopefully this will help someone else with the same problem.
The update is helpful.
It's not really cynical to point out that Volvo engineers weren't really worried about lifetime durability, only about durability beyond their warranty obligations. This has been true for a LONG time: The Deacon's Masterpiece, by Oliver Wendell Holmes "The Wonderfuil One Horse Shay" is the earliest example of design life I know of. |
(Post 414903)
