Starting problem 2000 S40
Old Feb 17, 2007 | 01:12 PM
airapetov's Avatar
Default Starting problem 2000 S40
Post by clp29445
< This evening I went out to start the car. I turned the ignition; nothing happened. There is little to no power available inside the cabin for lights, etc. I figured I must have left a light running inside the vehicle. Anyways, I used a battery charger on the battery for approximately 15 minutes then tried to start the car again. This time, I hear a fast-paced, repeated clicking noise when the ignition is turned on, which abruptly stops when I release the key. Also, the lights inside the cabin are again working normally. >
Instead of charging the battery I used jump-start cable. And still I got only clicking noise.
If starter is bad, how difficult to replace it and where it's located?
Thanks
Old Feb 17, 2007 | 01:21 PM
Default RE: Starting problem 2000 S40
The starter is located on the front of the car side of the engine.
It is kind of a pain to get to. You need to remove the intercooler hoses to get to it.
Old Feb 17, 2007 | 03:06 PM
airapetov's Avatar
Thanks Tech.
Does it sound like the starter is bad for you?
Old Feb 17, 2007 | 03:12 PM
If all you hear is clicking then most likely yes.
Make sure the engine turns over by hand. If so then the starter is bad.
tejas24478
Jun 11, 2011 10:24 PM
maines70
Feb 23, 2010 04:53 PM
BasilG
Mar 13, 2009 09:16 PM
mcaldwell
Aug 3, 2006 12:01 PM
sk799
Oct 17, 2005 09:16 PM
