Starting problem and gas smell
Old Oct 20, 2008 | 10:48 PM
renejuan's Avatar
Default Starting problem and gas smell
Hi:
My S40 is having problems starting in the morning. It takes about 5 seconds (and sometimes trying two times) before it starts. It smells a little like gas whenever I try to turn on the car. If I turn off the car and wait about 1 hour it will presents the same simptoms. Why is the fuel injection system losing its pressure so fast? The car is almost 90K. How likely is that the fuel pump is out. What should I check before letting the mechanic change the pump? Thanks.
Old Oct 20, 2008 | 11:44 PM
spw2e's Avatar
Default RE: Starting problem and gas smell
Actually, Volvo issued a voluntary extended 10 yr/150,000 mi warranty concerningthe fuel pump on certain Volvo models because oftentimes these fuel pumps crack or fail. As a matter of fact, I just had the fuel pump replaced free of charge on my 2001 S60 after I started noticing hard starts and the strong smell of fuel. To find out whether or not your car is covered under the warranty, you can contact Volvo Cars of North America at 1-800-458-1552 Mon-Fri 8:30 to 5:30. Good Luck!
Old Oct 21, 2008 | 07:51 AM
ORIGINAL: spw2e
That recall is only on the S60/V70 and possibly the S80's.
It does not include the S40.
renejuan: Check the fuel pressure regulator. Remove the black cover off the throttle cable setup. Then find the fuel pressure regulator on the end of the fuel rail. Then remove the vacuum line in the intake from the regulator. I will bet it either smells like gas or is wet from the gas. It is a pretty common problem.
Old Oct 21, 2008 | 08:07 PM
renejuan's Avatar
Thanks
petergreene
Jun 15, 2015 01:53 AM
drothelast
Mar 18, 2015 02:06 PM
navybluex2
Nov 14, 2010 06:19 AM
ppine31
Feb 15, 2008 02:56 PM
vipul_vips
Jan 26, 2008 06:44 AM
