TCM and ECM are not compatible 2005 s40
Old Mar 28, 2013 | 05:26 PM
JDaman's Avatar
Default TCM and ECM are not compatible 2005 s40
Hey everyone, I recently posted another thread but I've run into another issue.
I mentioned that I replaced the transmission on this s40 that I bought, that being said once I have driven it, the new transmission has all kinds of issues, one being that it does not manually shift into 1st gear.
It is almost undriveable, however ..
If i were to place the old TCM from the bad transmission into the new transmission, will this fix the problem? I need to know because it is a junkyard motor but if I do so it will void the return policy of this transmission if it ends up being bad. If it helps, the vehicle is running code: P0614 which indicates that the TCM and ECM are not compatible ..
I need help please and thank you!!!!
Old Jan 13, 2024 | 06:18 AM
Venk's Avatar
Did this issue is settled? Because I have similar problem can you please advise, I bought TCM from Aliexprss but they sent same part number but software is not the same maybe they sent TCM intended for Ford, so whether I can reprogram to suit for my Volvo V60 T4 2012? By TCM reload from VIDA database
eranga
Sep 24, 2021 06:46 PM
Gia1
Sep 15, 2016 04:15 PM
Danheck
Aug 23, 2015 07:46 PM
lner62quiet
Nov 14, 2013 05:02 PM
DONT DO IT
Jun 15, 2011 03:37 PM
