TRYING TO UPGRADE AIRFILTER
Old May 3, 2006 | 05:18 AM
thejman's Avatar
Default TRYING TO UPGRADE AIRFILTER
Hi i,m looking for some info on putting a sporty air filter into my vovlo s40 2001 1.8L. can it be done?And what website could i buy the filter on, i don,t want an induction kit just the filter.
I know the cone shaped filters make a sporty noise, but do the flat panel pipercross filters make any?
And will it do any damage to the engine if i do short term or long.
please help
jeff
Old May 3, 2006 | 10:53 AM
S70driver's Avatar
Default RE: TRYING TO UPGRADE AIRFILTER
Ok well the stock airbox is the best setup, since no heat can reach the filter.
1. Get a cone filter that doesn't use oil on it, and slap it on your MAF. This will get you your sporty sound, plus in the Summertime loads of heat soak which is really bad.
2. A panel filter will not get you that sporty sound, since it is inside an enclosed box. It probably makes the sound, but you cannot hear it.
You have a few options. A. Get an EST intake kit with what little heatshield they provide with it. B. Get a cone filter and creat your own heatshield. C. Just get a panel filter and be done with it. D. Do the Slater intake system which I posted his writeup on how to do it in another thread on the forum.
Old May 3, 2006 | 01:05 PM
reg's Avatar
reg
.............just remember...........oil soaked cotton (read K & N) will kill your MAF. If you go that route, OIL LIGHTLY!!!
REG
Old May 3, 2006 | 01:06 PM
thejman's Avatar
Thanks i think i,l try the cone filter attached to the MAF.
Will it damaged the engine in anyway short or long term?
Old May 3, 2006 | 06:08 PM
S70driver's Avatar
ORIGINAL: thejman
By using a cone filter? I am going to say no it wont. Using one with oil to be honest I didn't have a problem when I used mine, but maybe it wasn't on there long enough for a problem to start.
Try finding a cone filter that doesn't use oil. I think the APEXI one doesn't.
Just remember your going to get heatsoak like a bat out of hell, so be forewarned about it.
Old May 3, 2006 | 07:20 PM
reg's Avatar
reg
I agree with you S70................his performance is going to suffer big time unless he 'closes off' the hot air induction with some home made baffling. Not a good idea to suck in hot air! In fact, we used to run our gas line through a 'cool box' which was a can filled with ice cubes in an effort to keep things cool when racing. Hot air sucked into the engine is simply going to kill any performance that the less restrictive air cleaner is going to offer and then kill more performance simply by sucking hot air! The stock air cleaner draws it's air supply from cool air in front of the radiator (next to it) and it is placed there simply for the reason that the engine needs COLD air!
REG
Old May 4, 2006 | 04:53 AM
thejman's Avatar
Thanks lads cone filter so it is I don't think i'l worry that much about the heat soak though i,m living in ireland RAIN RAIN RAIN YEEE HAAAAH
Old May 4, 2006 | 01:10 PM
reg's Avatar
reg
.............the green green grass of home................
dcjcdc
Sep 25, 2008 10:09 AM
shadowlord
Jun 28, 2008 10:59 PM
JRXC70
Mar 11, 2008 08:28 AM
suter
Jan 2, 2007 10:41 PM
thejman
May 9, 2006 11:07 PM
