Undercarpet Foam 2005 Volvo S40
Old Sep 27, 2012 | 10:45 AM
Atlantakruz's Avatar
Default Undercarpet Foam 2005 Volvo S40
I need some help. I have a 2005 Volvo S40 with a sunroof. Every now and then the drain gets clogged and water backs up into the cabin. They should recall this issue but I guess that another problem for a later discussion. The carpet has been soaked several times and now there is mildew in the foam padding. I took out all the carpets to let dry and bleached the inside of the car to get the mildew out. I need to replace the carpet and the foam. Is there an after market place online that I can order the carpet or should I try cleaning the foam out? I don't think that there is a way of cleaning it since it's like a sponge. Any suggestions?
Old Mar 1, 2013 | 01:18 PM
jbravo8212's Avatar
You might want to look at this post: Water Leak - Volvo Forum : Volvo Forums
It sounds like your water leak may be coming from the AC Drain from the air box.
Abandonhouses
Nov 24, 2014 12:18 PM
TONY12340
Nov 20, 2012 02:38 PM
bbrian017
Dec 9, 2009 10:38 PM
Volgrrr
Nov 10, 2006 01:30 AM
bongo240
Jun 10, 2004 12:31 AM
