Very Technical Question - Engine upgrade
Old Nov 21, 2005 | 12:13 PM
SPJC's Avatar
Default Very Technical Question - Engine upgrade
Hi All,
I have an oportunity to buy a 2.0 litre s40 engine. Can this be put into my 1.8, what is involved? or am I better off just replacing the engine with another 1.8 when it goes?
OR - Is there any cheap and reasonably easy ways that I can increase the power on the 1.8?
Cheers
Old Nov 21, 2005 | 09:33 PM
Default RE: Very Technical Question - Engine upgrade
Do they look alike?
Here in the states we only have the 2.0.
Old Nov 22, 2005 | 04:43 AM
SPJC's Avatar
It does.. Is it a different ecu for the 2.0???
Old Nov 22, 2005 | 05:47 PM
ZIGZAG's Avatar
I am not an expert at motor swaps but you might want to check motor mounts. Make sure that they match, you can get into a heap of trouble if you have to change them. Is that motor coming with a trannie? Bolt up might be a problem.
Old Nov 23, 2005 | 07:48 PM
Black Beauty T4's Avatar
I suspect engine mounts would probably match (check first!) but gear ratios are different so new engine would need to come with matching transmission. ECU might be the same depending on which 1.8 is fitted, but software would be different. Ensure suspension, tyres (size and speed rating) + brakes can handle increased power/speed/weight. Good luck!
BB
Old Nov 23, 2005 | 08:07 PM
reg's Avatar
reg
Black Beauty made an extremely important point. So many want more power (read speed) and spend their last dime on obtaining the performance but do absolutely nothing regarding the safety issues such as upgraded brakes and speed rated tyres. I cringe when I see a kid's hot rod shaking down the avenue hoping that he is not near me when the suspension lets go or the tyres blow!
Reg
hardluck
Mar 3, 2012 02:20 PM
keaunym
Nov 17, 2010 12:55 PM
nicolaselias
Sep 18, 2009 08:51 PM
Sparkplugs.com
Engine & Internal
Dec 1, 2006 05:10 PM
