Volvo Oxygen sensor problems
Old Nov 22, 2017 | 05:09 PM
Guage's Avatar
Default Volvo Oxygen sensor problems
I have a check engine light for my oxygen sensor, does anyone know where the downstream oxygen sensor is located on this car? I have looked in my owners manual and cant seem to find out its location, I have also looked on the forums and haven't been able to find anyone with a similar issue. I have the 2000 Volvo S40
Old Nov 22, 2017 | 06:01 PM
check out
The sensor harnesses are located up on the firewall and then cable down to the exhaust/cat pipe. The specific OBD2 codes will indicate which sensor is bad. Note the front sensor measures o2 for fuel trim and the rear sensor measures cat efficiency. Both have a heating element which can go bad (and can even be subject to a blown fuse)
You may be able to see the front (upstream) sensor and reach from the top.
Old Nov 22, 2017 | 06:04 PM
Guage's Avatar
Originally Posted by mt6127
check out https://www.youtube.com/watch?v=jtTvfgbkrBU
According to the code it's Bank 1 Sensor 2. So the downstream, just not able to find where it is even after looking under for it.
Old Nov 22, 2017 | 06:26 PM
trace the wires - its probably on the top side of the exhaust after the catalytic converter. the two sensor systems have one sensor ahead of the cat to adjust fuel trim and use a second sensor after the cat to measure cat efficiency and "long term" trim
soduku007
Oct 7, 2019 04:01 PM
habbyguy
Nov 10, 2014 07:01 PM
egraffius
Dec 6, 2010 10:01 AM
dman777
Aug 18, 2009 10:47 AM
