Volvo S40/V50, European Edition 1.8L model 2008
Old Aug 9, 2025 | 12:51 PM
matdeinn3's Avatar
Default Volvo S40/V50, European Edition 1.8L model 2008
Volvo S40/V50, European Edition 1.8L model 2008. Engine Code B4184S11.
Air condition Flaps are not turning from Heat to Cold and vice versa. I manually turn the flaps from the driver's bottom side using a screwdriver from a hole I created, but it isn't an enjoyable job.
So the problem I suspect is that the flaps are stuck. Re-Calibration of the CCM can possibly solve the problem? What are my options here? To disassemble the whole dashboard and try to repair/replace the flaps or the flaps motor itself?I didn't visit any technician until now to get any VIDA error codes that may CMM return. So, can I manually reset the CCM module? How to know if the motor is bad or just the flaps are stuck? Can other ODB diagnostics from a 3rd party manufacturer re-calibrate the CCM module?
Regards,
Old Sep 23, 2025 | 03:18 AM
dhsyu's Avatar
Finally a perfect guide that tells everything you need. I personally own a V50 with a D4 engine, which as you said is very rare for this model and not many people know it even exists. They are actually still very expensive and keep on rising in price. It really is bulletproof and very fuel efficient. Bought it at about 170k kilometres 4 years ago, now has little over 250k kilometres. I will drive it till the engine fails, or the body rusts to dust. Have a feeling it still has a long way to go as my first car.
snaptube vidmate
Old May 31, 2026 | 07:05 PM
JulianButler121's Avatar
Bonjour,
Dans votre Volvo S40/V50 2008, si les volets de climatisation ne bougent pas, le problème vient généralement d’un moteur de volet défectueux ou d’un volet grippé. La recalibration du CCM peut fonctionner seulement si le moteur bouge encore correctement. Sans VIDA, il est difficile de recalibrer via un OBD générique, car les modules Volvo nécessitent souvent leurs outils pour lancer les tests et lire les codes.
Pour diagnostiquer, vérifiez si le moteur tente de bouger à la mise en marche et si le volet peut être https://ile-de-casino.pro/ déplacé à la main. Si le volet est dur, il est probablement bloqué ; si le moteur ne bouge pas, c’est lui le problème. Dans la majorité des cas, remplacer le moteur du volet est plus simple que de démonter tout le tableau de bord.
matdeinn3
May 31, 2026 07:04 PM
Georgeandkira
Jan 23, 2024 12:26 PM
camilo1949
Jul 15, 2019 08:16 PM
vLoke
Jan 10, 2018 05:26 AM
vLoke
Jan 9, 2018 02:34 PM
