Weird Electrical Issues (2005 s40 2.4i)
Old Nov 6, 2015 | 09:39 PM
ZachFman's Avatar
Default Weird Electrical Issues (2005 s40 2.4i)
Hello, I have a 2005 Volvo s40 2.4i. So far I've noticed two ongoing issues.
1: While Driving (especially when turning the wheel, the radio flickers and headlights dim). Also while in park or slow speeds, the lights (headlights too) flicker, power steering goes out, gauges go crazy all while a small thumping/pulsating sound is heard.
2. Sometimes, when I go to start the car, nothing happens almost as if it's dead, sometimes I get a message stating: key error try again. This might be a faulty ignition switch, but I'm not sure.
Any help is appreciated.
Old Nov 7, 2015 | 02:16 PM
s40_Ontario's Avatar
Battery and/or alternator issue? Is your battery more than 3 years old?
If you disconnect a battery terminal when the car is running does the engine stall? If so, you likely have an alternator issue.
Old Nov 8, 2015 | 08:12 PM
if you have a multimeter, do some quick tests - what's the voltage at the battery terminals - engine off (should be 12.5V or so). Now start the car. what's the voltage with the engine idling - should be 14V+. Now throw on the blower, lights, rear defrost etc. voltage at the battery should stay above 13.5 or so...
I'd be inclined to think you may have an ignition switch issue or a loose wire in the steering column. Next time you get the error message, try wiggling the key as well.
swiftjustice44
Oct 25, 2012 06:32 AM
merlotman
Jun 11, 2010 03:21 AM
96960Chris
Mar 19, 2010 08:38 AM
JFigliuolo
Mar 5, 2009 06:39 AM
Sweet740GLE
Jan 8, 2004 02:13 AM
