What's the cheapest clutch disk I can get for a Volvo S40? Do Ford Focus ones fit?
Old Dec 24, 2022 | 09:01 AM
Thaddeus_the_Bold's Avatar
Default What's the cheapest clutch disk I can get for a Volvo S40? Do Ford Focus ones fit?
Hi,
Odd request here.
I am converting a Volvo V70 to full electric. I obtained a 5 speed manual transmission from a Volvo S40 (2008?) and I am working on creating a coupler to mate it to my forklift drive motor.
I'm tryig to do this as inexpensively as possible, and I'd like to source the spline adaptor from a clutch disk-- will be taking that down to a driveline place and having them weld the splined piece to the motor's coupler to create the finished part.
What is the cheapest compatible clutch disk I could get for this application? I saw some talk online that some Ford products used the same clutch kits, and Ford parts are cheaper. Also saw chatter about Mazda clutches working.
Thanks in advance.
T
Old Dec 24, 2022 | 12:09 PM
will you require a pressure plate and fly wheel? if so, which fly wheel are you using the S40s or from the V70?
If you need a fly wheel, going used may be the best option. As to clutches, most are sold as kits - disc, pressure plate, slave cylinder, throw out bearing. I did a quick google tour and all show only one model of the Ford Focus so I doubt you'd get a deal that way. Sachs is the OEM supplier and LuK is a widely available after market. You should be able to get a kit for under $400 - so start by checking out FCP, EEuroparts, RockAuto, Partsgeek, ebay etc. I like to find a vendor part number (say for a Sachs or LuK kit on a bigger/better web store like FCP) then google around. Partsgeek looks to have the best prices and who may offer just a disc if that's what you need.
Old Dec 24, 2022 | 01:23 PM
No flywheel, no clutch. Electric motors don't need it. I'll start out in 3rd and drive to whatever speed I need.
I basically just need the splined coupler that's in the center of the clutch disk. Get that attached/balanced to the coupler for the forklift motor. Done.
Old Dec 24, 2022 | 09:52 PM
I'm wondering if you can get something from a recycle yard then. See if Erie VoVo (a volvo specialist) would sell you a used clutch disk. You can also try using car-part.com to see who's breaking up any S40s or other models that use the same transmission.
Old Jan 2, 2023 | 04:09 PM
I found one from a Ford Focus 2.0 Liter, perfect fit. 34 bucks.
PROGRESS!
GeneC
May 14, 2015 06:17 PM
Frans562
May 12, 2014 07:53 PM
misterbrooke
Jun 21, 2013 07:24 PM
timwu12
Mar 30, 2010 01:29 PM
pitchpipe
Nov 30, 2005 12:08 AM
