What's this light on the dash?(2001 S-40)
Old Dec 20, 2009 | 01:04 PM
Greenmudshark's Avatar
Default What's this light on the dash?(2001 S-40)
Guys, I have a 2001 S-40 w/ 110,000 miles on it.. When I start the car , no light appears on the dash..But as soon as I put my foot on the brake a light comes on the dash..It is an exclamation mark(!) in a circle that has lines radiating out from it.. I think it has something to do with the brakes but don't know and I can't find it in the manual... Any ideas???? Thanks
Old Dec 20, 2009 | 06:30 PM
MN2.5T's Avatar
It's the bulb failure warning light. It comes on when the brake pedal is pressed if there is a defective brake light bulb. Check your brake lights - either a burnt out bulb or a bad connection caused by corrosion in the socket.
Old Dec 21, 2009 | 12:39 AM
Goat's Avatar
Perhaps a dead bulb? But I am not sure.
- Goat
Old Dec 21, 2009 | 10:28 AM
Lyonsroar's Avatar
It means you're going to die.
No, it's the brake light out. Mine did this once but it stopped on its own...
Old Dec 21, 2009 | 01:23 PM
stash36's Avatar
Guys its not for bulbs, it is the low brake fluid warning light.
Get the fluid topped up asap, and if it comes on again, you've got a leak from somewhere.
Old Dec 21, 2009 | 04:50 PM
Lyonsroar's Avatar
You are wrong.
If the brake fluid is low (or other brake issues) a light will come on that says "BRAKE"
The exclamation point with the radiating circle is a brake light bulb failure.
Source: (halfway down the page)
http://new.volvocars.com/ownersdocs/...0_02a.htm#pg21
Bulb failure warning light
The light will come on if one of the brake light bulbs are defective when the brake pedal is pressed.
Check the fuse and bulb. See sections "Replacing bulbs" and "fuses".
Old Dec 21, 2009 | 10:30 PM
AutoNaut's Avatar
Brake failure warning light
If the light comes on while driving or braking, stop immediately, open the hood and check the brake fluid level in the reservoir. See page 116 for reservoir position.
If the control lamp still stays on, the EBD (Electronic Brakeforce Distribution) is not working.
Drive to your Volvo dealer. See ABS control lamp and also page 73.
Canadian models are equipped with this warning light:
Old Dec 21, 2009 | 11:08 PM
PeterKesel's Avatar
It's the bulb failure warning light. It comes on when the brake pedal is pressed if there is a defective brake light bulb.I think you can use Xenon Bulb for solve your problem.
Old Dec 22, 2009 | 04:58 AM
stash36's Avatar
The exclamation mark with circles is brake fluid on UK cars, mine doesn't have that BRAKE light. Guess he might have checked his bulb by now anyway!
Old Jan 12, 2010 | 02:07 AM
Vivi's Avatar
I had this light on my dash recenty...had a brake light out, fixed brake light... light's off.
Easy as that.
Old Mar 21, 2012 | 08:21 AM
privera19's Avatar
What if the light went off by itself and never came back, during the drive?
Old Mar 23, 2012 | 06:37 AM
Hudini's Avatar
Check your lights. If they work, don't worry about it. If one is out, replace it.
lister99
Dec 28, 2012 10:46 PM
trs80
Jun 25, 2011 02:05 PM
crosby1
Nov 21, 2010 04:08 PM
tr_car_nut
Jan 19, 2008 09:37 AM
