Window off tracks
So my window has come off the track i believe. When i hit the button the motor goes and no movement from the window.
Is there an easy fix for this? could i do it my self by taking the panel off, if so how do i do that.
Thanks
Thanks
Hello nick. My brother had a similar experience in his truck. Same symptoms. He took it in to a window/glass specialist and they had to re-glue the bottom part of the glass. They also spotted a bent rod(regulator??). I don't know the technical terms used because I wasn't there. They simply had to bend it back.Anyway the good news was they only charged him labor. It ended up being around $70. I'm sure anything done at the dealer will be much more than that. Is yours still under warranty? If not, call up your local glass specialist.
