Wiper arm
Old Dec 18, 2015 | 05:33 PM
Bemfica1's Avatar
Default Wiper arm
Passenger side wiper is not making contact with windshield. When in motion sort of lifts up and doesn't wipe at all. I was told I need to replace the wiper arm... Is that correct or there is a easier/less expensive way of fixing problem? Tks
Old Dec 18, 2015 | 08:04 PM
sure, simply bend the arm to give it some curve to press a bit harder (you may need to put a block under it to get some leverage). But before you do that, check to make sure the nut holding the arm on is fully tightened.
Old Dec 19, 2015 | 11:12 AM
pierremcalpine's Avatar
Also make sure that the joint has not seized. I had to spray some crap in mine for it to get its spring back. You will know if it's seized if you cannot lift it with ease.
colgate41
Nov 15, 2007 03:46 PM
jmana
Sep 19, 2007 08:02 AM
hohoho43
Aug 9, 2007 12:35 PM
Mass850
Dec 27, 2005 02:44 PM
Leovv
Mar 17, 2003 08:45 PM
