2002 S60 Clogged Vent Line?
Old Nov 16, 2010 | 01:41 PM
efd7989's Avatar
Default 2002 S60 Clogged Vent Line?
Hello, I have a 2002 S60 with about 140,000 miles. When filling up, gas backflows after about a few seconds. I took it into the shop and was told it has a clogged vent line. I was then told that to repair it, it will most likely cost upwards of $1,000! I was wondering if anyone has had any experiences similar to mine, and being your typical financially challenged college student, has anyone found a more affordable option? Thank you so much!
Old Nov 16, 2010 | 08:21 PM
Manu Noypi's Avatar
Go look for other repair shops or do it yourself so save big. If u can't do it, then u have no choice but to look for reputable shops or mechanic. Jack up the car and trace the filler hose going down to the tank and look for a hose connected to it. That is the vent line.
Old Sep 26, 2011 | 02:02 PM
JJ Joe's Avatar
I have a similar issue... It takes 15 - 20 minutes to fill my gas tank. The spigot continually shuts off. I have been to numerous stations and have tried many different positions of the handle (full in and moved out, positioned at 45and 90 degrees of normal) all with the same results barely run the flow and the tube fills and pump shuts off.
If this is a venting issue, how do you clean / clear?
Thanks for any and all help (other that sell the car)
It's a 2004 XC90 5 cyl Turbo
JJ
Old Oct 21, 2011 | 10:28 PM
Nichals's Avatar
yeah this is a problem in most s60's
most of the s series i belive
what i do is watch how many gallons are going in and when it gets close to full i just listen and as soon as i hear the gas begin to flow up i shut off the pump and everything is fine...just never have a friend fill up for you lol
there ya go the one thing you can fix on this car for free =P
Volvo_Neps
Oct 9, 2013 09:33 PM
PAVolvo850
Oct 24, 2012 08:16 PM
mhphoto
Jan 28, 2008 06:03 PM
ckuttner
Aug 9, 2007 08:26 AM
art
Aug 24, 2006 11:33 AM
