Volvo VIDA/DiCE Guide for S60
Old Feb 2, 2013 | 07:11 AM
Khoa's Avatar
Default Volvo VIDA/DiCE Guide for S60
If u recently got an "SRS Airbag Service Urgent" warning light from disconnecting the climate control unit. Or Flash your transmission fluid and want to reset the fluid counter. It will be explained below.
I used VIDA version 2011D with a Dice brought from eBay (a cheap chinese copy). I did it on my 2003 Volvo S60 AWD 2.5T.
(This is how i did my car so it may be different from other and now I'm sharing my knowledge to you.)
(I will not take any responsibility if you damage your car.)
Basic Installation:
*System Requirement*
Windows XP Professional, 2GB or more of RAM, 20GB of free space, IE 8.0 works best.
(I ran it of a virtual machine. And my VIDA version is 2011D.)
-Run the installation from Install\DVD\Vida_dvdheader\Main\setup.exe.
-Select VIDA All-in-one.
-Select language.
Than follow a few prompt.
-After that restart computer.
- Wait for the VIDA icon in the task bar to go green than click on VIDA All-in-one.
-Log in as: admin.
Connecting your Dice to VIDA
-Click on Vehicle Profile and under "Communication tools" select your Dice to "Read your car".
How to reset "SRS Airbag Service Urgent" warning light.
-First go to Fault Trace.
-Than delivery tab.
-Scroll down and click "READ ALL" to get all your error code.(get all error code check first)
-After error code get checked click on "ERASE ALL" to clear all code.
How to reset "Transmission fluid change counter and Transmission adaptation systems"
-First click on "Diagnostics" tab.
-Than click on the sub tab "Vehicle Communication"
-After that go to TCM module, than go to advanced tab.
-From there you click on Transmission Fluid Change Counter and fellow the instruction to reset both transmission fluid change counter and adaptation systems.
Hope this help your guys with your SRS warning light. Or resetting your TCM after a transmission flash.
Old Feb 6, 2013 | 02:24 PM
01_fast_ride's Avatar
Thanks for posting that. You know, I've never played around with Vida/Dice, but seeing how easy it looks I might just buy one. Great post.
Old Feb 8, 2013 | 05:30 AM
Khoa's Avatar
No problem. And VIDA is also a great software for viewing your car parts and how to tutorial for fixing certain things in your car.
Old Mar 2, 2013 | 08:46 PM
max81's Avatar
Where did you buy yours? I don't know which is the most trustworthy site
Thanks
Max
Old Mar 3, 2013 | 06:14 AM
Khoa's Avatar
Well i got mine from ebay. The seller sent it out very quick but the CD that the seller provided (VIDA 2012D software) it had issues installing. So i decided to download the software myself. The DiCE itself works fine no problem at all.
OBD Volvo VIDA DICE Diagnostic Tool OBD Scanner Volvo Scan Tool Newest 2012A | eBay
Old Mar 5, 2013 | 10:03 PM
max81's Avatar
Thank you,
how did you get the software at the end?
And what were the issues that you had with the CD?
Best
Max
Old Mar 8, 2013 | 05:53 AM
Khoa's Avatar
in the end i got software from piratebay (VIDA 2011D) good enough for me. the cd kept getting error code when installing. didnt care about the cd just wanted the DiEC reader in the first place.
Your Welcome and i would love to help anyone as much as i could
georgedsmith
Jul 10, 2021 04:31 AM
autonumen
Dec 25, 2011 08:11 PM
obd2be
Dec 23, 2011 09:27 AM
supmotelec
Oct 11, 2011 04:55 AM
JackBlair
Mar 3, 2011 05:56 AM
