The $600 oil change
Old Oct 30, 2019 | 05:44 PM
Pretorien's Avatar
Default The $600 oil change
OK, a bit more than an oil change but.....
60,000 mile service (based on time, not mileage - 52,000) - it's an oil plus filter change with plug change and cabin air filter added
Materials:
Castro Edge $57.68
Oil filter 18.99
Cabin air filter 80.33
Spark plugs 87.61
With the possible exception of the oil, the above are charged at about 2X the quoted retail price from most outlets (had I known that they were going to install the very expensive "multi filter" in the HVAC system, I would certainly have questioned the value)
Labor $371.20 (guessing the labor rate to be ~ $100/hour, this suggests a rate of activity best seen with time lapse photography)
Shop supplies $23.54 (pure silk wiping cloths?)
10% coupon
$595.65
And, to top it off, my complaint about the back light on the drivers side window control was denied as being not covered - to be taken up directly with Volvo HQ
Unbridled greed!
Old Oct 30, 2019 | 08:04 PM
ES6T's Avatar
I'd bet the labor rate is over $100 an hour. And yes, labor costs money.
Old Nov 1, 2019 | 07:25 PM
rickwol's Avatar
And why in the world (regardless of time) would you be replacing your spark plugs at 52k miles. 100k is the recommended interval.
Old Nov 1, 2019 | 09:20 PM
Pretorien's Avatar
per schedule
Old Nov 2, 2019 | 08:44 AM
ES6T's Avatar
Recommended by who? Not Volvo.
Old Nov 2, 2019 | 03:19 PM
you can go to https://www.volvocars.com/us/own/own...owners-manuals and download the maintenance schedule to see what Volvo publishes as the maintenance intervals for your car. no mention of the year/model but 60K miles for plugs seems the norm.
Old Nov 3, 2019 | 08:50 AM
rickwol's Avatar
Yes, I see that Volvo recommends spark plug replacements sooner then I've seen with other manufacturers. Did a quick check on my wife's S60 T6 and it calls for replacement at 75k. Getting close to that now.
Old Nov 3, 2019 | 10:29 AM
Pretorien's Avatar
Interesting....I wonder why the T6 (turbo/supercharged?) would have a longer plug life than the turbo T5? I forgot to ask the service dept to keep the old plugs for me. "Reading" the plugs can tell you a lot about the engine's operation. (Did some wrenching on a FIII Cooper with a 500cc Norton - 2 plugs, start on one and warm up then pull it and fit the (colder) plug to run.)
Old Nov 3, 2019 | 05:25 PM
maybe its because the T6 plugs fire 20% less per RPM than the T5 or maybe they are a different plug design?? On a 60K mile engine with FI and direct coils, there's probably not a lot to read from the plugs unless your car is consuming oil...
Old Nov 3, 2019 | 06:24 PM
Pretorien's Avatar
Originally Posted by mt6127
maybe its because the T6 plugs fire 20% less per RPM than the T5 or maybe they are a different plug design?? .
Good point - had not thought of that - would correspond to predicted electrode erosion
VDonkey
Aug 3, 2015 03:02 AM
air force rascal
Jun 8, 2008 01:51 AM
Tacodog
May 9, 2008 10:38 PM
luvmyXC90
Mar 23, 2008 11:51 PM
Spoonman
Nov 25, 2007 12:53 PM
