04' S60 wiper fluid nozzle came loose (?)
The passenger side wiper fluid nozzle has come loose and is dangling around....what hold these things on the hood? Some type of clip? Adhesive? Epoxy? What?? I took off the inspection panel underneath the hood and looked at the drivers side nozzle...looks just like the passenger side nozzle but its tightly mounted to the hood, I do not see any special clips holding it on.
What is holding these nozzles tight to the hood????
Any help would be greatly appreciated.
By the way, just mounted the IPD upper motor mount bushing, the oem part was trashed, this was a super easy install, highly recommended if your oem motor mount goes south.
Dustin
Dustin
Seems normal to me. I must have a different car from most, my motor is ultra smooth, almost cant tell that its running sometimes. Next up is the upgraded transmission mount, I like poly bushings way better than rubber, they seem to last forever.
Dustin
Any info on the wiper fluid nozzle??????
Dustin
Jimbo_Jones
12-05-2010 11:01 AM
