Driver/passenger climate controls
Old Jan 26, 2009 | 05:07 PM
kpevav's Avatar
Default Driver/passenger climate controls
2007 Volvo S60 AWD
This morning I noticed that the driver's side blows out hot air but the passenger's side does not, no matter what the setting. Any clue on why the heat would not flow to both sides?
Old Jan 26, 2009 | 06:23 PM
Default RE: Driver/passenger climate controls
Did you turn it all the way to cold then back to hot?
Sometimes you need to do that to recalibrate the temp motors.
Old Jan 26, 2009 | 06:55 PM
kpevav's Avatar
I just went out to the store and tried your suggestion, but it still blows cold on the passenger side. It gets quite hot on the driver's side, especially since it is still 67 degrees here in Orlando.
Old Jan 26, 2009 | 07:06 PM
Another Orlando person here!!!
The motor itself might need to be recalibrated by the Dealer.
They should do it under Warranty.
Old Jan 26, 2009 | 07:18 PM
kpevav's Avatar
Okay, it sounds like a trip to the Volvo Store later this week. Thanks!
Old Jan 26, 2009 | 08:38 PM
Good Luck please give us an update after you go.
If you happen to talk to Roland tell him I said Hi (Alan Johnson)
Old Feb 3, 2009 | 07:17 PM
kpevav's Avatar
The Volvo dealer found that it needs a new diaphragm, but had to order one and they will install it later this week.
One question: when they do that work (under warranty), would it be easy for them to install an iPod adapter (and save on labor), or is that a separate operation? Or will a dealer always charge separately?
Old Feb 3, 2009 | 08:36 PM
It depends on which one they replace and where it is.
I would ask them and see what they say.
Old Feb 6, 2009 | 04:21 PM
kpevav's Avatar
Default Heat flow on passenger's side fixed
Last Saturday they took 2 1/2 hours and found what they thought was a defective temperature damper motor, since it would not calibrate. Today, after installing it, they found it was an internal climate control issue, so they replaced the climate control unit, did a software reload, and calibrated the damper motors. It works and it was under warranty. Of course, the temperature now has warmed up.
They also quoted $585 for the iPod adapter, and suggested that customers had very mixed views about it. That is about $400 more than I would pay for it.
Old Feb 7, 2009 | 09:47 AM
That is a joke they had the radio almost out to do the climate module. It would have taken a short time to install it from there.
Old Feb 8, 2009 | 07:32 PM
kpevav's Avatar
Unfortunately, the guys on Webster Avenue seemed quite serious about the charge for the iPod adapter. Fortunately, the heat works now on both sides, just in time for the warmer weather.
Old Feb 8, 2009 | 08:21 PM
Yes they are very proud of their tech's that just come out of school and have no experience working on the cars!! They are only book smart.
bob-chalkley
Oct 13, 2025 10:51 AM
pete8475
Jan 31, 2025 01:06 AM
jipsy
Jan 22, 2012 06:00 PM
sasjzl
Oct 1, 2009 07:46 PM
rhecker
Oct 22, 2007 10:22 PM
