2001 S60 ECM problem?
My mechanic is telling me that I may have a faulty ECM and the car will have to go to the dealer since doesn't have the equipment to communicate with the ECM.
Symptoms:
- ABS/Traction Control lights on
- Check engine lights on
- ABS/Traction Control kicks in unneeded at low speeds
- Sometimes speedometer registers about half the speed I am going, when this happens the car will not shift into higher gear for a bit
- Once the temperature gauge maxed out even though coolant wasn't hot, then went back to normal after a while
I have replaced the ABS Module with one from BBA (didn't cure problem) next I replaced both front speed sensors (didn't work). Everyone blamed the ABS Module, so I called BBA and got a replacement and changed it out again, but nothing changed.
Could I have a bad ECM or bad software? Is the ECM something that I can replace myself if it is the problem?
Symptoms:
This is what the shop has on the ticket:
"Diagnostic code scan found all codes cleared with 1 pending code for PO500= to volvo ECM -510D Veh speed signal faulty, test drove and got failure codes PO500,P15000P0116 +code 032 wheel sensor faulty signal, code 022 wheel sensor faulty signal, code 092 control module communication fault, code 095 control module malfunction permanent fault, code 011 left wheel sensor faulty signal, refer to volvo dealer for possible PCM and or programming issues."
So....... how much is this gonna set me back?
Dealer is telling me it is definitely the ABS controller. I told them I had replaced it twice and it didn't make a difference. The tech says I didn't replace it with a "Volvo" controller. They want 1450.00 to replace it. I guess I'll pick it up and give BBA Reman another call. I find it hard to believe I have received 2 bad controllers.
dejan_da_dude
02-24-2015 01:17 AM
geniadillard
2001-2013 model year V70
12
03-28-2013 11:01 PM
