2001 s60 Engine suction
Old Jan 22, 2006 | 04:14 PM
tynasty's Avatar
Default 2001 s60 Engine suction
I recently bought a 2001 s60 (not a turbo). I noticed while ideling; there is a high pitced whistle that appears to be caused by too much suction in the engine (around the dipstick, and/or oil cap). Another odd symptom that may be related: if you pull the dip stick out or take the oil cap off while the engine is running the engine misses/ runs rough. Does anyone know what could be causing this, and how to fix it?
Thanks!
Old Jan 22, 2006 | 07:42 PM
Default RE: 2001 s60 Engine suction
I think you have a clogged vent box. It is building up to much pressure.
Old Jan 22, 2006 | 11:27 PM
tynasty's Avatar
Is this something that a dealer has to fix or can I take it to a mechanic? Where is the vent box located? Is there a relatively simple fix I can do myself?
Thanks for all your help.
Old Jan 23, 2006 | 03:51 PM
It is located on the front of the enine. At the back of the A/C compressor. You will have to remove the intake manifold to replace it. If you have patiance and tools you should be able to do it.
oreng
Aug 27, 2013 12:12 AM
TXS60T5
Jun 13, 2013 11:56 PM
VolvoS40S60
Jul 21, 2010 02:12 PM
jprizal
Jan 15, 2009 04:05 PM
michaud2005
Aug 1, 2005 12:00 PM
