weak low beams
Old Jan 24, 2006 | 07:46 PM
spinningcain's Avatar
Default weak low beams
On my 02 s60t the low beams a not good they just seem weak I took it to volvo and they said it was fine but it is not. Is this a common problem with these cars? Im going to try and put brighter bulbs in maybe it will help .............Jerry
Old Jan 24, 2006 | 07:52 PM
S70driver's Avatar
Default RE: weak low beams
They should be Osram Sylvania bulbs.
I had those in my S70 stock, I changed to Sylvania Silverstars and I likef them a lot better. Whiter light and I am sure they were brighter as well.
Old Jan 24, 2006 | 10:56 PM
Ya Im gonna get a set tommorow Hopefully it will be better cause there terrible now. Its the only dissapointing thing about the s60 besides the stupid "position light failure" message that I cant seem to get to shut off even though all the bulbs are working. I drove it last night and it was a little hairy in real dark areas. Anyway thanks for the reply.......Jerry
Old Jan 24, 2006 | 11:18 PM
S60 R's Avatar
U might want to adjust the headlights as well. It seems to be a common issue with S60's. I had the same complaint (even with xenons) until I moved them up, and they are great now.
Old Jan 25, 2006 | 12:01 AM
Ya thats the answer only I dont see the **** to adjust the up and down I can adjust them sideways. but not up and down Do you know were its located? thanks........Jerry
Old Jan 25, 2006 | 12:07 AM
Your headlight has 2 adjusters. One you have to go through the radiator support to get to it. The other is towards the top on the outside of the headlight. The one that you have to go through thr radiator support to get to should be the up and down adjustment. It is about in the middle of the headlight on the back side.
Old Jan 25, 2006 | 12:30 PM
Thanks Man Ill try and adjust them tonight. do you know if it takes a special tool or can I get to it with normal stuff? .........thanks for the replys.......Jerry
Old Jan 25, 2006 | 12:32 PM
Old Jan 25, 2006 | 05:12 PM
S60 R's Avatar
If I remeber correctly, u can use a regular socket wrench if u have a longer socket, or a small extension...I hope that makes sense. I forget the size though.
Old Jan 25, 2006 | 08:38 PM
It is a very small socket like a 4 or 5.5 mm socket. I always use a long extension and the socket.
Old Jan 25, 2006 | 09:02 PM
Right on man, Ill do it this evening thanks for the info........Jerry
98isb360
Oct 13, 2021 08:47 AM
bkhan145
Mar 16, 2019 02:22 PM
kwhitton
Feb 3, 2018 09:45 AM
MarkyD
Sep 5, 2006 08:01 PM
V50T5
Jul 20, 2006 03:15 PM
