2001 S60 Fuel Filter Replacement
I have two 2001 S60's and need to replace the fuel filter. Do I need a special wrench to replace the fuel filter and which fuse number should I remove to release the fuel pressure?
No special tools needed.
I just wait a while and slide the hose back a hair and let the fuel leak out slowly. Or after it sits for a little while drain the fuel through the schrader valve on the end of the fuel rail.
inilegna
Sep 25, 2013 03:27 PM
