1987 240dl Fuel Filter Replacement—Depressurizing fuel system question...
Old Sep 25, 2013 | 09:38 AM
inilegna's Avatar
Default 1987 240dl Fuel Filter Replacement—Depressurizing fuel system question...
Hi folks.
Need to put in a new fuel filter asap, but having no luck de-pressurizing the fuel system. I followed the instructions in my Haynes manual: remove the main fuel pump fuse, start car, its supposed to stall, then open the gas tank and good to go. Only problem is I removed both the main and internal fuel pump fuses and the car just doesn't stall out. Any recommendations or tricks? thanks!
Mark
Old Sep 25, 2013 | 03:27 PM
there is no fuse on the main fuel pump.
anyways, the residual pressure will at most make a little sput of fuel on a LH system, dont sweat it. its K-Jet systems that have a pressure accumulator and much higher fuel pressures where you would be concerned. do wear eye protection in case that 'sput' squirts a drop in your face ...
Midway
Apr 23, 2018 12:34 PM
AA752
Mar 28, 2014 09:33 PM
AnEskimo
May 15, 2011 12:32 AM
muckaluster12
Jun 12, 2008 07:31 AM
tanknamedalice
Sep 22, 2007 06:48 PM
